Arranging Internet Explorer favorites in alphabetical order?
Discussion in 'Archived Threads 2001-2004' started by Thane, Jul 8, 2002.
  1. Thane
    Thane Stunt Coordinator
    Jun 3, 1999
    112
    I'm using Internet Explorer vers. 6 and am wondering if there's any easy way to arrange the favorites bookmarks in alphabetical order. Seems like one time quite a while ago I clicked something & they all went into alpha order. But I wasn't sure what I had done! Can't find anything in the help topics for IE, and I have a lot of bookmarks so don't want to have to drag each one individually. Thanks in advance!
  2. Rob Gillespie
    Rob Gillespie Producer
    Aug 17, 1998
    3,632
    5
    Click on Favorites, hold the pointer over the list, right-click and select 'Sort By Name'.
  3. Thane
    Jun 3, 1999
    112
    Sounded easy, Rob, but I can't get it to work! When I right click over the list, it chooses the bookmark that is closest and gives the options for that individual bookmark (delete, open, properties, etc), but doesn't give a sort by option. I've right clicked just about everywhere on the list! I know it's got to be possible though!
  4. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    Thane,
    When I right click over an individual link in the main pulldown- I also get the options for that particular bookmark- but right above PROPERTIES at the bottom is SORT BY NAME (it's the second option from the bottom).
    It should be there if you're running ie 6 (I have 6.0.2600.000).
    -Vince
  5. Chris Rosene
    Chris Rosene Second Unit
    Nov 3, 1999
    336
    Works for me. Thanks!
  6. Thane
    Jun 3, 1999
    112
    How very strange! I too have version 6.0.2600.0000 and there is no sort option! Right above properties I have the rename & delete options! I'm using XP...would that make a difference??
  7. Todd Hochard
    Todd Hochard Cinematographer
    Jan 24, 1999
    2,312
    Strange. I use IE6 in XP, and I have the sort.
    Try this-
    Open My computer, then C:, then Documents and Settings, then your login name folder, then Favorites. Once the folder is open, right click, and Arrange by Name. You can open each of your subfolders in Favorites, and do the same.
    Todd
  8. Thane
    Jun 3, 1999
    112
    I tried your suggestion, Todd. They're in alphabetical order in the favorites folder, but still not in alpha order when I'm in Internet Explorer. I don't understand this at all...specifically why I don't have the sort option!
  9. Pete_S
    Pete_S Stunt Coordinator
    Apr 10, 2000
    239
    Thane, sorry if you've already tried this, but it seems like Internet Explorer is pretty picky on where you can actually sort, so I thought I'd double-check.
    The only place you can perform the 'Sort By Name' action is by clicking the Favorites button up on the, uh, toolbar where File, Edit, View, etc. buttons are. Just click that button, right-click a folder or favorite, and you should get the Sort By Name option. You can't sort if you're in the Organize Favorites... window (which makes no sense whatsoever, but go figure), and you can't sort if via the right window pane thing.
    Hope this helps.
  10. Thane
    Jun 3, 1999
    112
    Ah Pete! Thanks so much...struck gold with your suggestion! I have been in the left-pane list of favorites. Man...it IS picky!! Thanks again![​IMG]
