ARGH! I am tired of my skipping DVD player!
Discussion in 'Playback Devices' started by Blashy, Jan 17, 2006.
  1. Blashy
    Blashy Agent
    Jan 20, 2004
    31
    Ok, well since there seems to be nothing I can do, I have tried using a DVD player cleaner to no avail and I have made sure the disks are cleaned prior to playing.
    But too many DVDs still skip. I take the same DVD put it on my pc dvd player and it runs fine.
    So my 300$ home theatre in a box is a done for.
    I want to purchase a dvd player that is top notch in terms of NOT skipping.
    The places I intend to buy from are bestbuy.ca , futureshop.ca and http://www.braultmartineau.com
    Anything in there that is recommendeded?
    Oh and now I guess I am stuck to buy a seperate player for my speakers, my speakers connect via the simple standard speaker connections wires.
    Thanks for any help you can offer.
  2. John S
    John S Producer
    Nov 4, 2003
    5,460
    On build quality, look into Oppo players. They do seem to be a tad better than the $100 and under offerings.
    DVD players are made cheaply these days. Most of us, just replace the players when they go out. Skipping is a problem that comes with use and age, no real way around it, other than finding a better built player in general, which the Oppos seem to be a slight notch above most in the $200 and under range. They seem better built than my Zenith DVB-318 anyways whcih is also in that same price range.
  3. rob-h
    rob-h Second Unit
    Jul 6, 2005
    263
    I bought my first DVD player in 1997 for $900 and still have it. Not one player (even the cheap ones) that I have owned has ever skipped. I have never even heard of that before. Well, I guess you live and learn!
  4. John S
    John S Producer
    Nov 4, 2003
    5,460
    Well, I don't think skip is the term I would use. But basically any trouble reading discs could called skipping, which is what I am assuming is the case here.
    You never had a problem with a player reading discs? If so you are very fortunate. I think most of us have experienced DVD player problems with reading discs in general.
  5. Blashy
    Blashy Agent
    Jan 20, 2004
    31
    Oppo players. I'll look into it.
    I guess best thing to do is take the full proof warranties.
  6. Lance_R
    Lance_R Stunt Coordinator
    Dec 26, 2000
    130
    I had lots of problems with netflix in my players, I recently built an HTCP and not one single problem. I think you just need to find a player with a bigger buffer.
  7. Blashy
    Blashy Agent
    Jan 20, 2004
    31
  8. Steve_Blazer
    Steve_Blazer Stunt Coordinator
    Nov 29, 2003
    55
    The more expensive players have a memory buffer in them so it can resample the DVD and try to fill in the gap while you continue to watch the movie without interruption.
    I used to have a cheapo DVD player and it was a pig for skipping etc so I upgraded to a decent Denon with a 4meg buffer.
    No problems since.
  9. Blashy
    Blashy Agent
    Jan 20, 2004
    31
