Are these subs adequate?
Discussion in 'Home Theater Projects' started by Chris:-/OV, Aug 28, 2004.
  1. Chris:-/OV
    Chris:-/OV Stunt Coordinator
    Sep 7, 2003
    50
    Hi
    After having done a lot of reading I want to build a diy sub. Here in South Africa finding 8ohm drivers is very hard but I have come across these. What do you guys think? will they be any good and in what type of enclosure should i put them to get the lowest F3. Size of the box i will be putting 2 of either of these 2 subs in doesn't matter. What can you guys recommend for a sub that goes EXTREMELY LOW and LOUD for movies but will also satisfy for the occasional dance/hip-hop listen?
    All help will be appreciated.
    Regards
    Chris
  2. Chris:-/OV
    Sep 7, 2003
    50
  3. Dan Hine
    Dan Hine Screenwriter
    Oct 3, 2000
    1,312
    Chris,
    Unfortunately neither of those drivers will go extremely low for movies. They really seem better suited as woofers in a 3way live audio speaker cabinet.
  4. GrahamT
    GrahamT Supporting Actor
    Sep 13, 2003
    556
    Yeah, those are not subwoofers. Even car subs would be better than those. If you cant find any good DIY sub drivers, have you considered www.svsubwoofers.com ? They are not a lot more expensive than a DIY sub.
  5. Jack Keck
    Jack Keck Second Unit
    Nov 23, 2001
    269
    "They are not a lot more expensive than a DIY sub."
    They might be if you count shipping to South Africa.
  6. Greg Monfort
    Greg Monfort Supporting Actor
    May 30, 2000
    884
    Since 8ohm drivers are hard to come by, what rating(s) is plentiful that have a low Fs?
    GM
  7. GrahamT
    Sep 13, 2003
    556
    D'oh! :b
