Are these good?
Discussion in 'Archived Threads 2001-2004' started by ChrisHeflen, Mar 6, 2003.
  1. ChrisHeflen
    ChrisHeflen Supporting Actor
    Sep 9, 2002
    912
  2. Bob McElfresh
    Bob McElfresh Producer
    May 22, 1999
    5,182
    The Fusion line from Radio Shack is new so the jury is still out. The cables from the custom sites use professional grade Canare/Belden coax. The Fusion cables are pretty, the pro stuff is hard, stiff, ugly. But a cable that fights tight bends is better for the signals.
    No comparison - use the stuff the pros use.
  3. RayJK
    RayJK Stunt Coordinator
    Nov 25, 2002
    131
    I've been into audio for 35 years but this is a new one to me.
  4. Bob McElfresh
    May 22, 1999
    5,182
    When the frequencies get higher, reflections become a problem. (We are talking MegaHz here, not audio that tops out at about 22 khz). To solve this, the signals need to see a uniform 75 ohm impedence through both connectors and the coax to the destination.
    Coax cables work by suspending a center wire in the middle of a "pipe" and maintaining a uniform distance between these two. This means they share the same axis which is why we call it "Co Axial" or coax.
    A tight bend in a coaxial cable changes the uniform distance at that point. This is visible/measurable with video analysis equipment. (See some of the tech notes on the Belden web site).
    So a thick outer sheath that fights tight bends helps maintain the uniform impedence of the cable.
    This also applies to computer network cable. To maintain catagory 5 network compatability, the cable can have no more than 4 90 degree bends in the run.
