Are there any receivers with 6 channel analog output?
Discussion in 'AV Receivers' started by Harminder, Oct 25, 2003.
  1. Harminder
    Harminder Second Unit
    Apr 24, 2003
    462
    I'm looking for a receiver that has 6 channel analog (RCA cable) audio output (not input) because, I want to use the optical audio output from my satellite receiver to a home theatre receiver and use its 6 channel analog audio output to another receiver that takes only 6 channel analog input. I know it sounds complicated but that's the best I can do to explain it LOL.
    Bottom line, is there a receiver that has 6 channel analog output?
    Thank you.
  2. CurtisC
    CurtisC Second Unit
    Jan 7, 2003
    369
    Yes,lots of them,most over 4-5 hundred dollar range.
  3. Greg Thomas
    Greg Thomas Second Unit
    May 3, 1999
    438
    Any A/V receiver that has 6 channel pre outs has analog outputs.
  4. Devin U
    Devin U Second Unit
    Jun 23, 2002
    399
    Have you ran out of optical imputs? Or is the other reciever not capable of DD/DTS? If you just ran out of imputs, I have seen optical "switchers" at radio shack and Fry's electronics for about 20 bucks. That would be cheaper than any super budget reciever. If you do need a new reciever for the decoding, try finding like a Sherwood 7106 or 6108. I have the 7106 and love it. The 6108 only diffrence I think is PL2.
  5. Harminder
    Apr 24, 2003
    462
    Thank you for all the info guys.
    Anymore models and their model #'s for the receiver type I am looking for would be greatly appriciated!
  6. Brian L
    Brian L Cinematographer
    Jul 8, 1998
    2,904
    10
    NAD 762
  7. John Garcia
    Jun 24, 1999
    11,571
    24
    NorCal
    Marantz SR5300 and up all have multi channel out.
    Denon 280x and up.
    Onkyo TX-SR701 and up
    Harman Kardon AVR-325 and up (which probably also means the 330 and up for the new models)
  8. Bill Will
    Bill Will Screenwriter
    Dec 26, 2001
    1,282
    I would say that the lowest-priced Receiver with 6.1 outputs is probably the JVC RX-8030VBK followed by the Pioneer VSX-911 & then the Kenwood VR-7070 just incase you looking for a budget models. In your post you din't say how much you would be willing to spend or what you wanted to spend ?
  9. Harminder
    Apr 24, 2003
    462
    All great information thank you so much to every one.
    I'm looking for a receiver with a good brand name, good quality but at the lowest price.
    I'm willing to spend between $400 - $700.
  10. Keith Mickunas
    Keith Mickunas Cinematographer
    Dec 15, 1998
    2,041
    Yamaha's from the RX-V640 on up have them. It's possibly on some of the HTR series also.
