Are there any online Laserdisc stores? (1 Viewer)
Nick Jablome
Anyone know of any that are still around, or a place that has a store locater? I've tried using search engines and i haven't come up with anythings.
ChristopherDAC
AE5VI
Sure.
Big Emma, www.bigemma.com
Ross' Exchange [a HT dealer in CA] www.rossexchange.com
Laserflicks [Canada, but no tariff across the US border] laserflicks.com
And a number of others. If it's used discs you're looking for, and most will be used, the easiest way to get them is through searching Jeff's Used Movie Finder www.usedmoviefinder.com -- he searches the best part of them on a daily basis. Also check out the Laserdisc Database, lddb.com which is setting up a "User Shops" feature. If you're into LD, lddb has everything to recommend it.
Hope this helps. :)
Logos1204
