I have a brand new H/K 525 that I do not want to harm in any way, shape, or form. I need to send audio (stereo) information to another room that is wired to the same location as my H/K 525. Someone recommended that I use the Niles HDL-4 speaker selector to drive "room b" stereo speakers, but I am concerned that the load would be harmful to the receiver.
I have the system configured as a 7.1, so I cannot utilize the "multi-room" feature H/K offers. The "room b" speakers are small Outdoor polks Atrium45's (see specs below).
Will a speaker selector be harmful to use?
If not, which speaker terminals should I split? The fronts?
Which speaker selector would you all recommend?
Thanks for your help.
Brian C
Tallahassee, FL
Go Noles.
Polk Atrium45
Overall Frequency Response 75Hz - 20kHz
Nominal Impedance 8 ohms
Recommended Amplifier Power 10 - 80 w/channel
Power Handling (continuous) 80 w
Power Handling (peak) 160 w
Efficiency 89 dB
Brian C
Tallahassee, FL
Go Noles.
Polk Atrium45
Efficiency 89 dB
