Jean-Francois Masse
- Oct 4, 2000
I was surprised to see that Hannibal (the feature) is silver even if it's rsdl. Explanations please.
Does anyone else feel cheated when their DVD-9 is silver instead of gold???
While I wouldn't put it that way, silver RSDLs do make my life tougher. Sometimes I forget if I saw a layer change while I watch a disc, and I'll just look at it to figure out if it's dual-layered or not. Sometimes it's a tough call, and that lovely golden tone helps me!
Time for a new petition - only gold RSDLs!!!
Colin Jacobson
DVD Movie Guide
www.dvdmg.com
A dual-layer disc has two layers of data, one of them semi-transparent so that the laser can focus through it and read the second layer. Since both layers are read from the same side, a dual-layer disc can hold almost twice as much as a single-layer disc, typically 4 hours of video (see 3.3 for more details). Many discs use dual layers. Initially only a few replication plants could make dual-layer discs, but most plants now have the capability. The second layer can use either a PTP (parallel track path) layout where both tracks run in parallel (for independent data or special switching effects), or an OTP (opposite track path) layout where the second track runs in an opposite spiral; that is, the pickup head reads out from the center on the first track then in from the outside on the second track. The OTP layout is designed to provide continuous video across both layers. The layer change can occur anywhere in the video; it doesn't have to be at a chapter point. There's no guarantee that the switch between layers will be seamless. The layer change is invisible on some players, but it can cause the video to freeze for a fraction of a second or up to 4 seconds on other players. The "seamlessness" depends as much on the way the disc is prepared as on the design of the player. OTP is also called RSDL (reverse-spiral dual layer). The advantage of two layers is that long movies can use higher data rates for better quality than with a single layer.
