Are people hibernating this winter?
Discussion in 'Archived Threads 2001-2004' started by Patrick Sun, Feb 11, 2003.
  1. Patrick Sun
    Patrick Sun Moderator
    Jun 30, 1999
    38,751
    482
    9,110
    I think the DIY projects are moving at a crawl this winter. I can't really think of much I want to do for the spring when it warms up enough to work in the garage. Anyone else got the DIY blues?
  2. Greg Yeatts
    Greg Yeatts Second Unit
    Feb 26, 2002
    300
    I have the DIY blues. I won't route in the garage because everything gets covered by MDF dust. This leaves Saturdays as the only time I can get anything done. Makes a project move awfully slow. Its also been to cold for glue to dry in my garage. Winter stinks. We need an eary spring.
  3. Ronnie Ferrell
    Ronnie Ferrell Second Unit
    Jul 16, 2002
    355
    I want to veneer my sub! But my garage is too cold for the tung oil to dry... [​IMG] Well it would dry, but it would take at least 2 weeks per coat...
    I wanted to use my power tools so bad last weekend, I resorted to making a "uber cat scratching post" out of some scrap MDF and sisal rope I had.
    rf
  4. ChristopherD
    ChristopherD Stunt Coordinator
    Mar 28, 2002
    107
    According to Punxatawny(sp?)Phil you're out of luck. As for me, I need to...continue to get to know my router, master veneer, buy and learn how to use a Jasper jig, build patience to sand for long periods of time, learn how to make straights cuts with my table saw, order A/V1+, and put all of the above into practice. Such are the positives of being new. More frustration, less consternation.
  5. Lee Carbray
    Lee Carbray Second Unit
    Oct 23, 2002
    308
    I've got Mdf, a Shiva, a plate amp and a garage at -20 degrees C .[​IMG]
  6. Seth_L
    Seth_L Screenwriter
    Apr 5, 2002
    1,553
  7. Dave Poehlman
    Dave Poehlman Producer
    Mar 8, 2000
    3,813
    Yeah, I'm the same way. I have some rear channel mini-bookshelfs and a new enclosure for my Shiva to build. However, it's too damn cold to be cutting MDF.
    Maybe I'll have Home Depot cut it for me.
  8. ChristopherD
    Mar 28, 2002
    107
    I know what you mean.
    It was, like, 60 degrees yesterday. I almost had to put on a sweater.
    California [​IMG]
  9. Chris Carswell
    Chris Carswell Supporting Actor
    Mar 5, 2002
    598
    I feel ya Chris. Today in FL it almost got below 65.......
  10. Shawn Solar
    Shawn Solar Supporting Actor
    May 12, 2001
    763
    -17Celsius is Pretty cold for here. I got av1+'s on the go and two 12" subs I picked up from the adire OEM sale that will serve as stands for the av1+'s. Before that is done I have to build a garage so I have a place to work. Can't do that cause the ground is frozen. 60 degrees, The house is 64 degrees at night(timed thermostat). If the ground wasn't frozen I'd be outside right now[​IMG]
  11. TimForman
    TimForman Supporting Actor
    Dec 4, 2002
    847
    Damn the cold, full speed ahead! I'm building my Adire LCC cabinet this weekend, despite the fact that they're backordered on AV8s. My garage is above freezing so that's good enough for me.
  12. Brett DiMichele
    Brett DiMichele Producer
    Sep 30, 2001
    3,181
    My garage is heated now so that is not an excuse. The
    excuse is that I am not doing any cutting in the garage
    I don't want MDF Dust on my Vette's (they are filthy as it
    is from me blowing a hole in the block for the new Stove's
    Chimney Pipe).
    That plus the fact that I need to use my friends table saw
    and he won't cut inside his garage either... I have all the
    stuff laying here to build my AV-12 but have yet to start..
    [​IMG]
  13. Michael R Price
    Michael R Price Screenwriter
    Jul 22, 2001
    1,591
    My new DIY amplifiers heat my room noticeably during the cold winter months. [​IMG]
    Well, once those are completely done it'll be time for a mostly figured out DIY DAC, preamp and crossover. The Kit281s are doing fine... no reason for another speaker project just yet. So no, we're not all hibernating. But waiting for a Tumult is definitely a good reason to be hibernating.
  14. Jeff Rosz
    Jeff Rosz Second Unit
    Sep 24, 2000
    335
    heya patrick,
    im gearing up. i just unloaded ten 5x5 boards of baltic birch (that i practically stole) this past saturday. three of which will be finely machined and crafted into a no holds barred tummy sub. the cutting starts tomorrow after i tune up the saws. should be 65 and sunny here. got some Disturbed burned on a cd to cut by too. some cocobolo(i need more), veneer, dye, forstners, and a few nick-nacks are in the mail. also been contemplating a vacuum press, we'll see. let the carnage begin.
    oh,btw,patrick...the bing cherry dye you used on your speakers...would you describe it as having a "candy" appearance? this red is what i am trying to match, looks more like the mahogany brian bunge uses huh?
  15. Jeffrey Noel
    Jeffrey Noel Screenwriter
    Sep 11, 2001
    1,533
    No DIY blues from me! I'm now painting my SCH K05B50 enclosures I just built on Saturday. It's amazing how fast you can cut using a jig-saw outside with a temperature fo 30 degrees F! [​IMG] The hammered paint job is coming out quite nice! Just letting it dry so I can start putting a polycrylic protective clear gloss on them.
    Next up is a ~1cu.ft. enclosure for my 12"DVC. This will be going in my car. And then I'm going to build an enclosure(volume not decided on yet) for my ever so wonderful AV12. Boy that sub is a beauty!
    I'm also learning how to use my new Bosch fixed base/plunge router combo. Love it so far!!
  16. Chris Tsutsui
    Chris Tsutsui Screenwriter
    Feb 1, 2002
    1,865
    The weather was a bit wet today due to a storm, temperatures still remain in the 60s, 70s though here in Socal.
    As for DIY, I'm designing a cheap 2-way using the Dayton PT2 planar tweeter and a Dayton 6.5" woofer. It'll be my first ribbon tweeter experience. Crossover will probably be at like 3khz, 12db/2nd order.
    Then I'm gonna upgrade my GR-Research AV-3s to sonicaps.
    Last I still need to primer and paint tempest #2 and spray on finish tempest #1. Oh, and make one amp box and paint my car's 2-way speaker enclosures.
  17. Patrick Sun
    Jun 30, 1999
    38,751
    482
    9,110
    Jeff, that red on the B&W is a little darker than what I wound up with with the Bing Cherry, which is a bit darker than candy apple red, but shinier/brighter than the B&W finish. Of course, if you put more coats of the Bing Cherry you could come up with a deeper red, I guess.
  18. Mike Nep
    Mike Nep Stunt Coordinator
    Apr 12, 2002
    93
    Just bought the MDF to build a pair of Ellis 1801's. It's raining here in San Diego for the first time in about two and a half months... Always rains when I need to pick up wood!!! Sorry about the -20 degree garages. Can't even fathom how cold that is. Anyone building anything else???
  19. Jeff Rosz
    Sep 24, 2000
    335
    right. the b&w's in person are not at all shiny. the pics at brian's site are the closest ive seen. i didnt order the bing cherry, i wanted to ask your opinion of it because website pics never look like real life. i ordered the mahogany red and i'll experiment with drops of black to darken it up, then some satin on top. thanks man, good thread.
  20. Andrus_R
    Andrus_R Stunt Coordinator
    Oct 19, 2002
    109
