are flat tubes progressive?
Discussion in 'Archived Threads 2001-2004' started by Talal, Apr 17, 2002.
  1. Talal
    Talal Stunt Coordinator
    Feb 6, 2002
    138
    forgive the newbie-ness of the question, but I was wondering:
    Do the 27" flat screen TVs from Sony, Toshiba and Samsung support what is called progressive mode?
    For example, if I have a game console that outputs a game in 480p, will the set be showing it in this resolution?
    thanks in advance for the help,
  2. Saurav
    Saurav Cinematographer
    Feb 15, 2001
    2,174
    I don't think so. I think you need a TV that's HDTV or HDTV-ready or something like that to be able to handle progressive signals. I believe Samsung has a 27" flatscreen progressive-capable TV, as well as a 27" flatscreen regular TV.
  3. Jack Briggs
    Jun 3, 1999
    16,738
    129
    Saurav is correct. The set must scan at the appropriate frequencies to be able to produce a 480p image.
  4. Talal
    Feb 6, 2002
    138
    A follow-up question:
    Is there a noticeable difference on a 27" flat tv with anamorphic squeeze when it comes to interlaced vs. progressive?
    i'm asking for both DVDs and games.
  5. Jack Briggs
    Jun 3, 1999
    16,738
    129
    On a 27-incher, the differences between prog-scan "squeezed" images and their interlaced counterparts are less noticeable, but they are there. Non-critical viewers might not notice any differences; they will all go "ooh" and "ahh" when looking at a 16:9-encoded DVD movie on such a set (interlaced, that is).
