Archival programs?
Discussion in 'DVD' started by Sam Favate, Sep 8, 2005.
  1. Sam Favate
    Sam Favate Lead Actor
    Feb 3, 2004
    6,700
    1,428
    9,110
    Sam Favate
    Is there an archival program, like a DVD Profiler, for music CDs? Can anyone recommend one?
  2. Scott Kimball
    Scott Kimball Screenwriter
    May 8, 2000
    1,500
  3. TimJS
    TimJS Second Unit
    Nov 25, 2001
    312
    I'm not a DVDProfiler user, & am not sure what comparable features you are looking for...
    I used to use guzzlefish cos it was free (& not because it was good).
    I just downloaded Music Collector , which seems to have all the functions & flexibility I need. I thought it was pricey, but looking at Readerware recommended above, appears to be about right. You can download a trial version to see if it works for you.
    I put my disc in my drive, Music Collector scans for CD ID & goes out to freedb and retail web sites to pull in available data & art files. I can input the UPC and pull more info, and I can modify the record locally (changing 'Various' to 'Various Artists' for example). All of this takes a bit of time depending upon how much you want to control the data...& whether you are satisfied with the data available in the free dbs and the un-modified presentation of that data.
    The program will allow you to export as html, so you can upload to web.
    Hope this helps,
    Tim
