Arcam, Rotell, Classe? (1 Viewer)
Nick Bum
Ok Im looking for a quality two ch. integreated amp for my new JM Lab 906 speakers. They recomend an amp with between 25-75watts.
The amps that I am looking at are as follows;
Arcam Diva 65
Classe CAP 80 or 100
Rotel RA-01/02
Rotel RA 1062
Now all of these amps should be in my price range. Which amp will be the best? I listen to a lot of rock music but I listen to other stuf too.
Right now Im leaning towards either the Arcam Diva or the Rotel RA-01 becaause they are the cheapest and they are avaliable in my area.
Scott_N
My choice would be the Arcam. I think it has a clean detailed sound without being bright. It's only 40 wpc though and could be a little light in the bass if you like hard rock.
John Garcia
NorCal
I really like the Arcam also. Sounds awsome, compact and the very simple looks works well. If you have a large room and demanding speakers, it might have trouble with bass heavy tracks, but for average listening, it should be fine. It's a pretty potent, HONEST 40w.
eathree
