ARC Help! (1 Viewer)
AN90
Aadi
have a situation in hand, was wondering if you had some insights to share
Hardware
- LG smart TV ( runs webOS), it comes with two HDMI ports, one is ARC supported
- Sony home theater (DZ290K) bought somewhere in 2010, with a HDMI port, No Digital Out, usual 3.5mm aux out
- Home theater alone, functions all right. 3.5mm aux cable works okay.
- However, ARC from TV is not relaying audio to home theater, with (SMP link enabled on TV and toggled with multiple options)
- the same home theater did pass the 5.1 output when it was connected to a Sony TV using ARC ( so am sure, the home theater is able to route audio using ARC, but i may be wrong if it used a SONY Bravia sync if it uses a different technology)
- What I haven’t tested at this point is to test this with a different HDMI cable
Would you have any suggestion on how to achieve a 5.1 output out of TV to the home theater?
Any recommended set up/approach/hardware?
TurtlePen
