Matt Weldy
- Feb 4, 2002
Is acoustic research cables good enough or do I need to spend the extra and get monster
Is acoustic research cables good enough or do I need to spend the extra and get monsterI like to suggest keeping the cable budget to 10% of the cost of the equipment you are hooking up.
AR is fine quality for a budget price. But when you move up to a more 'sensitive' level of equipment, then the 10% rule and your system should indicate a higher-end cable.
Lets break this down:
VIDEO:
Use AR brand until your system becomes sensitive. Then go to a custom cable site like www.bettercables.com and get the production studio stuff.
By sensitive I mean your system has one or more of the following:
- Display size bigger than about 40"
- Display is a HD/HD Ready unit
- Pushing Progressive or HD signals
- Long run between source and the TV
COAXIAL-DIGITAL:
This is simply a 75 ohm video cable. Just buy a good quality video cable and you will be fine.
SUBWOOFER:
The higher the frequency, the more effect the cable can have. But a subwoofer carries very low frequency sounds, and the difference between the lowest and highest frequency is small. This means any decent audio interconnect will work. Go with AR brand here, or a budget cable from one of the custom sites.
I don't have Monster cables, but instead have the AR pro series (blue cables). To me they are well made and I was able to negotiate a good price.AR'S blue cables are its performance seriesnot the pro series
