AR Banana plugs - differences and specs?
Discussion in 'Archived Threads 2001-2004' started by inazuma, Sep 23, 2002.
  1. inazuma
    inazuma Extra
    Jun 13, 1999
    16
    Looking to buy some banana plugs for my speaker wires... Looking at Acoustic Research with their HT407 (Pro) and the MS807 (Master) plugs.
    The HT407 is the compression type and is limited to 10 AWG, the AR's website doesn't say what type of connection the MS807 has... Anyone know if it is a compression or screw type as well as what the max gauge of wire it can handle?
    Lastly, will I be able to make a 12 AWG wire fit into the HT407 even though it is only rated for a 10 AWG wire?
    Thanks-
  2. Bill_Weinreich
    Bill_Weinreich Second Unit
    Sep 25, 2000
    317
    I use the 407 pro series without any problems. I have 4 strands of 16 gauge (equiv. to about 10ga) in each one. 12 gauge wire is smaller than 10 so you will have no problems with them fitting.
    Bill
    edit:
    p.s. it appears the other plugs you've mentioned are designed to fit on a certain speaker cable they make which is already terminated. It is merely an adapter.
  3. inazuma
    inazuma Extra
    Jun 13, 1999
    16
    Thanks for the checking and clarifying. Guess the 807 is out of the picture then.
    I had a brain fart earlier too... I meant would a larger gauge fit with the 407? So could I cram a 8ga wire into the 407 even if it says the max is 10? Just wondering how much you can really cram into that thing.
    In any case, thanks for the info.
  4. Bill_Weinreich
    Sep 25, 2000
    317
    Like I noted above, my wire was equiv. to about 10 gauge and it was tight. I don't think you'll be able to use any larger.
    Bill
