Ok, thermal paste seems to be the last frontier of computers that I'm not knowledgable in...Well I'm sure there is much more. Anyway on to the dumb questions. One thing I have noticed is that when I apply the paste to the CPU and fasten the heatsink...If I happen to pull the heatsink off again there is next to no paste on the CPU, it's all come off. I'm assuming this is not the case when the heatsink remains fastened. Also, should the thermal past only be applyed to the CPU? Should it also be applied to the proper area of the heatsink? Is there a link to a tutorial that anyone can leave for me? Thanks, Jeff
Go here: http://www.articsilver.com/arctic_si...structions.htm Even if you're not using Artic Silver (which you should 'cause it's great) these instructions are helpful. The biggest mistake most people make is applying too much compound. BTW, when you apply and later disassemble your HSF from your CPU you really need to totally clean the old compound and re-apply from scratch.
Yeah, the arctic silver tutorial is great... Im building my computer soon, and im glad i stumbled on their tutorial. Ohyeah, for anybody looking for a good deal, SVC has some good prices on Arctic Silver thermal paste: http://www.svcompucycle.com/thermalgrease.html A tube of Arctic Silver 3 for $4.99USD free shipping. I bought myself a small tube of Arctic Silver Alumina for $2.95 with free shipping (choose the FIRST CLASS shipping method).
Alright, you guys got my attention. I've been just peeling off the blue tape on the HSF and neglecting the thermal compound. Is that a no no? I don't have any heat issues at all. CPU temp is between 40-42C. How much cooler will my CPU be w/thermal compound? Correction: I just rebooted and found CPU is at 46C.
I assume the blue tape stuff is a thermal pad. If you pulled that off and have the heatsink sitting right on the processor, then its not transferring the heat very well. There's GOT to be SOME thermal compound to transfer the heat from the processor to the heatsink... I'd recommend getting some, the link above has really good prices (free shipping as well) on Arctic Silver products and great service. I ordered a tube yetserday and it has been shipped to its destination today.
When I apply thermal grease to a CPU or Bridge or any other item that requires an interface material I always clean the core and HSF with Laquer Thinner and then Isopropyl Alcohol. For my P4 I measured the P4's IHS and masked that size area off on the HSF and I gently "rubbed" Arctic Silver II into the base of the HSF. I then applied a little more to the HSF and spread it evenly and did the same with the core. I use a piece of plastic wrap over my finger so that the oils in my finger tip do not contaminate the paste. Another tip is to polish (or lap) the base of your HSF with varying grits of sandpaper all the way up to 2000 grit if you want the absolute smoothest surface. No surface will ever be free of valleys, even a 2 Micron Polish which in the machining world is about as good as it gets, still has valeys. That's why "rubbing" the Arctic Silver is a good iead. That way you work the particles into those valleys ensuring an even thermal contact.
Yeah, you gotta clean that off before applying the thermal compound. The arctic silver tutorial above is great. I believe it tells you to clean off all the residue with acetone or like rubbing alcohol.
