Apple Cinema HD Display?
Discussion in 'Displays' started by Estevan, Jun 30, 2003.
  1. Estevan
    Estevan Stunt Coordinator
    Jun 26, 2001
    127
    is anyone using this as a primary display? i realize it is a bit pricey considering it is only 23", but, believe it or not, that size will fit my immediate needs much better than my current display (Unity Motion UHD-3200). i'm in the process of finishing up my Ph.D. and am going to be doing a post-doc for the next two years; as a result, moving my current system twice is going to be cost-prohibitive (at least once cross-country!), so i'm going to try to sell it off and downsize to a smaller, more portable system (a two-channel system with a smaller display like the Apple Cinema HD). i was thinking i'd use the display in combo with a DVDO iScan Ultra, connecting it to the display via the Apple DVi to ADC adapter, this way i can use set-top sources (ReplayTV and progressive-scan DVD player) as well as computer sources... if anyone has experience with this unit, or is using a similar setup, i'd be interested in hearing your opinions about it.
  2. Gabriel_Lam
    Gabriel_Lam Screenwriter
    Mar 7, 2002
    1,402
    If you end up with one, make sure you get one made Feb/03 or later.
  3. Estevan
    Jun 26, 2001
    127
  4. Gabriel_Lam
    Mar 7, 2002
    1,402
    The Cinema HD display. Apple silently upgraded to the newest Lucky Goldstar Philips 23" panel that month. It's a huge improvement, especially in total average response time.
