Apocalypse: Audio problem
Discussion in 'Archived Threads 2001-2004' started by THOMAS VITA, Dec 19, 2001.
  1. THOMAS VITA
    THOMAS VITA Auditioning
    Aug 18, 1998
    2
    I am getting total silence and a "No Audio" message when the actual film starts. Menus are fine.I am Having this problem with My Mits. DD-6000 player only. All other discs play fine and AN plays perfectly on 5 other players I've tried it on. On my second disc: Still the same problem.Anyone having a similar problem? Mits is actually a Toshiba 3109 clone and disc worked fine on a Toshiba 6200.
  2. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    What is your receiver?
  3. THOMAS VITA
    Aug 18, 1998
    2
    The "No Audio" message is coming directly from the DVD player. This Player does not like this DVD. Just wanted to know if this is unique to me, or a problem with this particular model.
  4. Scott David
    Scott David Stunt Coordinator
    Oct 9, 2001
    184
    2
    I'm assuming you're referring to the "Redux" DVD, because I have the same problem with mine! When I hit "Play Movie" from the menu, the movie started...with no sound. Flipped through some of the chapters; still no sound. Then I got the bright idea of going back to the menu, selected the first scene from "Scene Selections"...and the movie restarted with sound! Didn't have a sound problem (or lack of) from then on. Very strange. Does anyone have a possible explanation for this?
  5. John Sturge
    John Sturge Stunt Coordinator
    Aug 18, 2001
    208
    Be careful, I blew out my Jmlab Cobalt speakers, and bottomed out my Sunfire Signature Subwoofer on Apocalypse Now Redux.
    Remember, listen to it at reasonable levels. Nobody wants to be put in my position.
  6. Peter Kim
    Peter Kim Screenwriter
    Jun 18, 2001
    1,577
    Yes, I brought this up when Redux first came out and I thought I was the only one, too.
    I have a Tosh 3109. Exact same symptoms as your described. My workaround involved the following:
    First, go into trailers. The sound comes alive.
    Exit trailers, then play movie. The sound will resuscitate itself.
    It's quite bizarre...I'm not sure how this could be a software compatibility problem with the 3109 if the sound does pop up once you prance around a bit.
  7. chris larralde
    chris larralde Stunt Coordinator
    Jan 14, 2001
    187
    Add the Toshiba 5109 to the list of players that have this problem. I'm going to try the scene selection to see if I can kick the audio in.
    chris
  8. BarryNS
    BarryNS Stunt Coordinator
    Aug 23, 1999
    91
    Ditto for Toshiba 4109 DVD changer. "No audio" on my Yamaha 995 until I went into the scene selections first and started the movie from there with Chapter One.
  9. YANG
    YANG Second Unit
    Feb 10, 1999
    471
    2
    I did not encounter any problem with the audio of this disc,but a serious one with subtitle.The subtitle dissappears after the layer change.
    My player is the PHILIPS DVD951.
