Eric_E
- Aug 8, 2002
Hi everyone, I apologize if this has been asked before - I did a search of the forum but couldn't find a satisfactory answer. I'm interested to hear everyone's opinions.
I'm planning to make my first home theater purchase (receiver/speakers) within the next few months and I'm trying as best I can to plan everything out in advance and anticipate problems. I have a question about how to run my speaker wires for my surrounds.
I live in an apartment, so running the wires in-wall is not really an option. I also probably won't be able to tear up the carpet to run the wires under there. I would prefer not to have wires running across the floor (even if they were covered by those flat plastic covers. So as far as I can see, my only realistic option is to run the cable along the baseboards of the wall and up and over doors when necessary.
The problem that this creates is that it requires a huge length of wire (probably 50' or more for each speaker, and I intend to have four surrounds for a (for now pseudo-) 7.1 system. This means 200' of wire, and if I intend to use 12 gauge, this will also be a huge bundle of wire running along the base of the walls. Speaking of which, is there any problem with running speaker wires so close to each other?
So, to get to the point, does anybody have any suggestions about my options? Right now I am thinking I may just end up trying to run the wires under the carpet after all, but is this bad for the wire? will it wear on the insulation? So many questions... I appreciate your help and suggestions.
Eric
Eric
