Anything to do to improve standard cable signal?
Discussion in 'Archived Threads 2001-2004' started by Dan Kolacz, Apr 12, 2002.
  1. Dan Kolacz
    Dan Kolacz Stunt Coordinator
    Dec 9, 1999
    83
    Hello,
    I have 1 coax cable coming into my house that is on a 2-way splitter that goes to my TV and cable modem.
    I realize that cable is inherently noisy and a crappy signal, but is there anything I can do to improve it?
    I have heard of boosters and other inline devices...do these really work?
    If so, is there any specific unit/model you can suggest.
    Also if there is any specific configuration/setup I should be considering (other than digital cable or satellite)
  2. Darrel McBane
    Darrel McBane Second Unit
    Oct 8, 1999
    363
    Biggest help to my system was one of these.
    http://cgi.audiogon.com/cgi-bin/cl.p...3818913&2&3&4&
    It also gives a big improvement to the audio end of a system. Price may be more than some want to pay. But, the results merit the extra cost IMO. I also use a Mondial Magic box.
    Having your cable company come out and check the signal and replacing old cable lines can also do a lot of good. That's of course if they actually want to give you a good signal.
    Good luck.
  3. SteveA
    SteveA Supporting Actor
    May 25, 2000
    700
    Make sure the splitter is a high-quality splitter - rated 5-1,000 Mhz. Also, you might want to replace the cable run to your TV with RG6-quad shield. I wired my whole house with that and my picture quality is great.
