Anything better than a Tempest for $150??
Discussion in 'Archived Threads 2001-2004' started by BrianJ>Y, Feb 28, 2003.
  1. BrianJ>Y
    BrianJ>Y Stunt Coordinator
    Jan 2, 2003
    99
    Gonna build a sub soon for strictly HT and need to pick out the driver. I've decided to power it with either the PE 794 or the rythmik 350watt plate amp. Gonna be a 5ft^3 ported enclosure and I'd like to get a pretty flat response from around 80-23hz. Would there be something better than the Tempest for my needs and budget of under 150? Im wondering how the tempest compares to the titanic mk2 12" and the Shiva...torn between these 3 drivers. Any help would be appreciated, thanks.
    Oh and my room is about 22'x16'x9' with an opening leading into the kitchen on one of the long walls.
    -Brian
  2. Javier_Huerta
    Javier_Huerta Supporting Actor
    Mar 9, 2002
    619
    I simulated some response curves using the Titanic, and it goes a bit deeper in a sealed box. I'd assume I'd go for a Titanic in a music only environment.
  3. Stephen Hopkins
    Stephen Hopkins HW Reviewer
    Jul 19, 2002
    2,598
    If budget is your main concern (other than flat to 23hz and 5ft^3) then a Shiva will definitely get the job done. Check out the vented Shiva application white paper and look at both the SBB4 and EBS Shiva enclosures. I think the much smaller Adire alignment would even meet your criteria. I built an EBS Shiva as my first DIY project and absolutely love it. I can't imagine needing more sub that what I have. Pair it up with a PE 250W amp and you're in business.
    That said, I got my Shiva driver for $75 used and there were no used Tempests available at the time... there are some used Tempests available now. If I had been buying a new driver, the $25 difference probably wouldn't have kept me from getting the Tempest... It's everything that's great about the Shiva, only better. If you absolutely need to save the cash and are buying new, the Shiva won't disappoint, but if you don't mind buying used or $150 won't break the bank, go w/ the Tempest. Either way you'll be able to build a GREAT sub that will far exceed the requirements you have set... I've checked the frequency response of my Shiva in my room down to 15hz and it still hasn't rolled off a bit! (my room is 12' x 12' opening up into a kitchen and two hall ways)
    Hope this helps [​IMG]
  4. Bryan Michael
    Bryan Michael Supporting Actor
    Mar 2, 2002
    564
    my advice is to save 50 bucks more and get a av15. i have 2 and wow it puts my velo ct 120 to shame. i spent 500 on it and 700 on the dual av15. it took a while for the drivers to get made but it was worh the wait.
  5. BrianJ>Y
    Jan 2, 2003
    99
    Thanks for the responses guys. The difference between the rythmik and PE amp is $30, which option would be best with a total of about $275?
    1. Shiva + rythmik (275)
    2. Tempest + PE (270)
    or
    3. Tempest + rythmik
    So I guess my question is really if there's any difference in sound quality between the two amps that justifies the price difference? I'm assuming the extra power is probably a wash...mainly concerned about sound quality.
    -Brian
  6. BrianJ>Y
    Jan 2, 2003
    99
    After doing some research i'm about to rule out the tempest or any 15in driver because the enclosure would have to be too large in order to achieve the same flat response as a Shiva in an ebs alignment. Am I correct in assuming this? SO now that i've decided on 12" drivers, given my preference for flat reponse and limited enclosure size(5ft^3), it's down to either the Shiva or the Titanic mk2...which I'll be waiting for pick up on ebay(hopefully).
    If I do go with the Titanic MKII 12" would I be able to achieve the same flat response as the Shiva in the EBS alignment or would I need a different design?
    -Brian
  7. Owen Bartley
    Owen Bartley Second Unit
    Nov 11, 2002
    487
    I'm with Brett. Take a look at the AV-12, it displaces almost as much as the Tempest I think!
  8. ross ish
    ross ish Stunt Coordinator
    Nov 18, 2002
    163
    Don't overlook the blueprint closeout at audioliquadator. the blueprint 1201 has similar spec to the shiva for $70.
  9. Bryan Michael
    Mar 2, 2002
    564
    the av-12 also looks cool. i dont think i am going to cover my subs av-15
  10. ThomasW
    ThomasW Cinematographer
    Nov 6, 1999
    2,282
    Your room is pretty big (3000+ cu ft). Using a single 12" driver you aren't going to get a ton of bass.
    IMO using a 15" (AV15?) in a smaller enclosure is a better choice. Bass reproduction is all about displacement. Usually a 15" will provide approx 50% more swept volume than a 12".
  11. Jonathan_D
    Jonathan_D Stunt Coordinator
    Jan 22, 2003
    142
    Where are you picking up used Tempests or Shivas?
  12. BrianJ>Y
    Jan 2, 2003
    99
    Hi guys,
    I wasn't planning on buying any used equipment(no warranty?). Instead I planned on waiting for a partsexpress auction on ebay for the titanic 12" or I would just get the shiva for $125.
    I've considered the Stryke av12's and 15's but they do cost a lot more(% wise) than a shiva and an auctioned titanic. I'm also under the impression that if I was to go with the av12 or 15 then I'd have to spend more for higher powered amp? After reading some threads it seems like the av12 is less sensitive and would require more power to really see the benefits over a shiva or titanic.
    My main goal is to get a neutral/flat response and with 5ft^3 of enclosure space I thought a 12" would be best to accomplish this.
    If however, you're all telling me that going with an av12 and an amp like the rythmik(350watts) is going to give me significantly better performance than a shiva/titanic with the PE 250watt amp then I suppose i'll be willing to shell out the extra cash...
    Also, is the DVC 12" a clone of the shiva?
    -Brian
  13. Peter Jessee
    Peter Jessee Stunt Coordinator
    Sep 25, 2000
    149
  14. BrianJ>Y
    Jan 2, 2003
    99
    Peter, your dvc sub looks awesome, the grill was a nice touch and I like the finish. If you don't mind me asking what is the finish, how do you apply it, where did you get it? Also what kind of port did you use? I'm gonna be starting construction soon and I was aiming for a look just like yours.
    Oh and I decided on an AV12...should be great.
    -Brian
  15. Peter Jessee
    Sep 25, 2000
    149
  16. TonyiBe
    TonyiBe Stunt Coordinator
    Jan 30, 2003
    96
    Peter,
    How do you modify the rumble filter. I seen the PE pdf of it, but how did you chose what you wanted... Never mind Dustin showed me how...
  17. Peter Jessee
    Sep 25, 2000
    149
  18. Seth_L
    Seth_L Screenwriter
    Apr 5, 2002
    1,553
    I'd recommend the Titanic Mk II, Shiva, or BPD 1201 in a 6cu-ft box tuned to 20Hz. They'll be less than 2dB shy of a AV15 in an 8cu-ft box tuned to 20Hz on the same power. The Mk II, Shiva, or BPD will the AV12 and the DVC 12", but the AV12 and the DVC12 only use a 3.5 cu-ft box tuned to 20Hz.
    See for yourself (380W of power):
    [​IMG]
    Blue - AV15 in a 8 cu-ft box @ 20Hz
    Orange - Titanic MK II in a 6 cu-ft box @20Hz
    Purple - DVC 12" in a 3.5 cu-ft box @20Hz
    Yellow - AV12 in 3.5 cu-ft box @20Hz
    Seth
  19. Seth_L
    Seth_L Screenwriter
    Apr 5, 2002
    1,553
    Ok, I modeled up just about every sub mentioned here in a 5cu-ft enclosure with 250W tuned to 20Hz (except the AV12 and 12" DVC tuned to 17Hz).
    [​IMG]
    green - Tempest
    blue - AV15
    magenta - Shiva Mk III
    yellow - Titanic Mk II
    grey - BPD 1201
    purple - 12" DVC
    white - AV12
    The BPD 1201, Shiva MK II, and the Titanic MK II are all kissing cousins. Seeing that the BPD is cheap at audio liquidators I'd say that's probably the way to go.
    The AV12 and the 12" DLS needed that lower tuning or a smaller (3.5cu-ft) box.
    The AV15 really needs a larger box (8 cu-ft), and the Tempest needs ~9 cu-ft.
    Seth
