Anyone using Virtual Dub?
Discussion in 'Archived Threads 2001-2004' started by Andre F, Aug 24, 2002.
  1. Andre F
    Andre F Screenwriter
    Dec 9, 2000
    1,486
    2
    I'm a total newbie (yes, I've checked out VCDhelp.com) and wondering if the files I'm capturing should be as big as they are. For about 11 minutes of video the file was well over 500mb. I'd appreciate any help, thanks.
  2. Peter D
    Peter D Stunt Coordinator
    Aug 16, 2000
    232
    The file sizes of raw captured video tends to be gigantic. I haven't captured via Virtual Dub (it doesn't support DV capture), but I use it to work with avi's captured elsewhere. You need to remember to select compression from the video menu to pick a codec (and full-processing mode then compression in the audio menu to do the same). Using MPEG4V2 for video and MP3 for audio, I've compressed a 45 gigabyte video down to under 500 megs.
  3. Jeremy Allin
    Jeremy Allin Supporting Actor
    Oct 6, 2001
    895
    The MPEG compression I get thru VirtualDub is approximately 10Mb/per minute. These are also VCD compliant.
  4. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    Hey Andre, did you buy that DVC80 you said you were getting?
  5. Ken Chan
    Ken Chan Producer
    Apr 11, 1999
    3,301
    It depends on what codec you're using and the frame size/rate. If the codec is one where every frame is independent (all key frames) like Huffyuv or some flavor of MJPEG, then at a full frame, 500MB for 11 minutes is on the small side. (DV is 2GB for about 9-1/2 minutes.) For MPEG, it's in the ballpark for MPEG-2, but high for MPEG-4 (although there are many variables).
    //Ken
  6. Andre F
    Dec 9, 2000
    1,486
    2
  7. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    Hows it working out? Did you have any trouble with the audio capture?
  8. Andre F
    Dec 9, 2000
    1,486
    2
  9. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
    I haven't captured anything for awhile, so i dont know if i can answer everthing.
    1. CaptureStudio to capture, also winVCR demo
    2. Camcorder and VCR
    3. Not sure of file sizes. I've tried converting directly to DivX before (i have one file thats 5:11 long and is 7.28MB), it worked, but not the best way to do things
    4. I havent made VCDs, so i just keep it in DivX.
    Sorry i couldnt be more helpful
  10. AaronD
    AaronD Stunt Coordinator
    Dec 4, 2001
    234
    I use a codec called HuffYUV for lossless capturing. It gets 2.5:1 - 3.0:1 compression ratios. It's still not MPEG-2 level compression, but it's also not lossy like MPEG-2.
    If I'm creating a DVD I capture to this first, do all my processing in VirtualDub then after all that is done compress it down to MPEG-2. It still takes up hordes of space (~500MB/minute @ 720x40x30fps), but it's better than raw. [​IMG] Plus, I can do it in real time on my P4 with many CPU cycles to spare.
    -Aaron
