Anyone using a slot 1 V0S32 heatsink/fan? (1 Viewer)
Jeff
I just got one of these huge GlobalWin heatsink/dual fans for my slot 1 P3 1GHZ and it's actually caused my case temp to go up 3 degrees over the Golden Orb I was using before. Shouldn't the VOS32 be better? I've read a couple really good reviews on it, saying it was the best.
Jeff
Camp
Did you use any thermal grease? Are you positive it was making even contact with the core?
Jeff
Yes, using thermal grease, but I will redo it via Arctic's intructions. I hope the chip is touching the core, otherwise the clip that comes with the Globalwin is no good.
Jeff
brettjv
