Anyone tried the tornado gas saver?
Discussion in 'Archived Threads 2001-2004' started by Drew Bethel, Jun 12, 2002.
  1. Drew Bethel
    Drew Bethel Screenwriter
    Nov 22, 1999
    1,209
  2. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    I'm going to go with gimmick on that one [​IMG]
  3. John Miles
    John Miles Stunt Coordinator
    Jan 16, 2000
    236
    Total snake oil. If it worked, the manufacturers would be using them.
  4. Henry Gale
    Henry Gale Producer
    Jul 10, 1999
    4,628
    Copper bracelets, magnets on water lines, green edges on CDs...
  5. kevin_tomb
    kevin_tomb Stunt Coordinator
    Dec 19, 2001
    146
    Its been proven to be TOTALLY BOGUS.......enuff said..
  6. Cam S
    Cam S Screenwriter
    Jan 11, 2002
    1,524
    Sport Compact Car did a test on it, and found NO GAINS! Though the maker of this thing said they found gains on a dyno, but Sport Compact Car wouldn't believe it.
    those 2 guys from the TV show "Shade Tree Mechanic" are in their adds endorsing the prodcut, how could they seel out like that, man oh man.
  7. Henry Carmona
    Henry Carmona Screenwriter
    Feb 7, 2000
    1,299
    San Antonio
    Henry Carmona
    Save your money.
  8. Daren Welsh
    Daren Welsh Supporting Actor
    Jan 16, 2002
    660
    I bursted out laughing when they said they based their design on airplane jet engines (I'm an aero/astro engineer). Too bad cars don't use jet engines. There are good reasons for jet engines to "stir up the air", but those fan blades aren't spinning to increase fuel efficiency. They're spinning to COMPRESS the air. A simple layer of stators (non rotating, curved blades) on a piston engine won't do crap.
  9. AllanN
    AllanN Supporting Actor
    Mar 15, 2002
    950
    I have no idea about the "tornado" but I got about .5 to almost 1 GPM more plus better throttle response when I installed my K&N air filter. I paid $50 but its good for up to 1,000,000 as long as you clean and re-oil it every 30-50k. I have a 2000 Ford Ranger Extended Cab, 3.0v6, 2WD, 5 Speed Manual.
  10. Daren Welsh
    Jan 16, 2002
    660
    Well, the air filter actually can make a difference as it allows air to flow more freely. The same goes for "coffee can exhausts". While they sound all ricey, they actually give you a small increase in HP and efficiency by decreasing back-pressure. The tornado, however, won't do crap.
  11. NickSo
    NickSo Producer
    Jul 2, 2000
    4,260
    Nick So
  12. Todd Hochard
    Todd Hochard Cinematographer
    Jan 24, 1999
    2,312
    K&N lets more dirt in, with more air. If you plan on owning the vehicle into high mileage, this could be a problem down the road. Otherwise, enjoy.
  13. Henry Carmona
    Feb 7, 2000
    1,299
    San Antonio
    Henry Carmona
    From K&N:
  14. Todd Hochard
    Jan 24, 1999
    2,312
    A real independent test. If I were racing, there's no question I'd use one (and I have). BUT, there is no way that a K&N will see use on my '95 Accord, which I intend to run 250K+ miles, without ever getting into the engine. I'm at 112K so far.
    Todd
  15. Henry Carmona
    Feb 7, 2000
    1,299
    San Antonio
    Henry Carmona
    Sorry Todd, but I think ill trust a barage of tests, included tests done by the SAE over one mans test.
    It may be a credible test, but the odds are against him.
  16. Kyle M. Krueger
    Mar 17, 1999
    38
    Im a territory sales manage for NAPA in Michigan, and I get these things for free... K&N Air filter, improves hp and gas mileage. The Tornados are selling crazy as are the K&N filters, I have a tornado in my car as well, My gas mileage went up 2 mpg, so its working for me.
    Based on the number of sales that I have seen in the Michigan area of the Tornados and K&N Filters they are not bogus, go to your local NAPA store and pick on up.
  17. Todd Hochard
    Jan 24, 1999
    2,312
    We agree to disagree, then. I simply can't find any data that says the K&N is better at filtering than a good pleated filter. More HP, sure, if you think 3-4HP is going to make a world of difference.
  18. Henry Carmona
    Feb 7, 2000
    1,299
    San Antonio
    Henry Carmona
    Well, its more like 9hp for me Todd.
    The thing is, when you add up all the "small" bolt-on's and other mods, you get a pretty good amount of HP for the little work involved.
