Nelson Au
- Mar 16, 1999
I have one of the first LD/DVD players, the Pioneer DVL-700. It still works and I use it in the home office.
However, it did eat two DVD's. The first time it was trapped along the edge of the disc between the spindle clamp and the tray. I had to take the cover off and force it out. (It did damage the DVD a bit and causes pixellation at the scratched area, damn!) It played discs fine after that for a few more years. Then last night, it did it again, though luckiy, when I took the cover off, I found it sitting on the tray askew. One very slight scuff.
I suspect the disc is not releasing from the spindle, but can't be sure. I also wonder if the player mechanisms are getting dry with age.
Anyone have this experience? Or know of a fix or tune-up procedure? I know that the complexity of the mechanism that has to deal with an LD and a DVD creates the problem and the best solution would be to get a cheap SD upconvert DVD only player and use the Pio for LD's only.
Thanks for any insights! Nelson
