Anyone seen these stands?
Discussion in 'Archived Threads 2001-2004' started by Chris Kane, Mar 20, 2003.
  1. Chris Kane
    Chris Kane Extra
    Dec 4, 2002
    23
    I've busted my budget (just as I figured I would) so I'm on the hunt for reasonably priced speaker stands. Has anyone seen these stands? Impressions?
    parts express part number 240-744
    Does anyone know of a better product for this price range? I don't want to spend more than $200 per pair.
    Chris
  2. ChadLB
    ChadLB Screenwriter
    May 5, 2002
    1,523
    Wouldn't it be easier to make your own. You could make them exactly like the parts express ones if you wanted to. It would be alot cheaper..just a thought.
  3. ChrisHeflen
    ChrisHeflen Supporting Actor
    Sep 9, 2002
    912
    Those stands look great. IMHO
    As long as they will put your speaker at the right listening height then you should be fine. (Usually that is at ear height when your seated). It also looks like you can fill them which I would most definitely do. They also have spikes which will help you couple them to the floor.
    Check out this link to Audio Advisor this will give you an idea about what's out there. I would definitely shop around though if you find something on there you like 'cause they are full list price people. http://www.audioadvisor.com/store/ca...&CategoryID=55
  4. Chris Kane
    Chris Kane Extra
    Dec 4, 2002
    23
    Chris,
    Thanks for the link. If I go with these stands I'm going to call to confirm that they can be filled.
    Chad,
    Since I'm currently amassing info in preparation for making my own cables, I don't want to take on another project. If I had more time I certainly would.
    Chris
  5. Matt_VA
    Matt_VA Auditioning
    Mar 20, 2003
    Here is another option for a fairly inexpensive pair of stands. This is what I recently purchased for my theater. they seem to work good, and these can be filled.
    http://www.btech-usa.com/bt606.html
  6. Victor Chan
    Victor Chan Stunt Coordinator
    Dec 10, 2002
    79
  7. Chriss M
    Chriss M Second Unit
    Dec 14, 2001
    320
    The problem i had with the parts express stands was the top plate was actually too big for some speakers. When i had Paradigm studio 40's, you could see about 1/2" of the plate on each side of the speaker while it was sitting on the stand. Personally, i thought this looked horrible. They were good stands, but you might want to measure the width of your speaker cabinets first.
    I'm now using Sound Oraganisation Z522's. They are about $150 a pair. http://www.soundorganisation.net
  8. Chris Kane
    Chris Kane Extra
    Dec 4, 2002
    23
    Victor,
    Thanks for the link. It's always helpful to read a review!
    Chriss,
    Glad to hear from someone who has owned these. The larger top plate is actually good for me as the speakers (M&K S-150) have a rather large footprint.
    Questions - the review supplied by Victor indicates that the speakers are black. However, the parts express photo makes them look gray. What color are they? Also, did they come with rubber feet or something to protect hardwood floors?
    Chris
