Steve Stogel
- Jul 19, 2000
Correct me where I'm wrong. As far as similarities, they use the same ports. As far as I can tell, that's where the similarities end. Is that right?
As for the differences, the Plus is the same enclosure as the CS and PC series, and the Ultra is a beefed up version of the 20-39s (birch endcaps and thicker tube). Correct? So how much nicer is the Ultra enclosure than the CS/PC/CS+ enclure?
Last but not least, the woofer. I thought they used the same woofer, but looking at the Web site, I think I was wrong. The Ultra is the TV-12 driver (produced by SVS?) and the Plus uses a db12 woofer (produced by TC Sounds?). Could anyone explain the difference in the woofers (in layman's terms); i.e., magnet size, excursion, et cetera?
Does that about sum up the similarities and differences? If so, the more important question is are the improvements (enclosure and woofer) worth the extra cash to have? I know the bang-for-your-buck route would be the Plus, but how much nicer are the ultras?
Steve
Steve
