William Moore
- Sep 5, 2014
- William
Hello. I own a Velodyne SPL1200 series 2 Sub which I have had for many years. I'm using this with my suite of Boston Acoustics speakers, the VR Series, and a Marantz SR7007 7.1 channel receiver. As you can see, all my gear is more or less "recent vintage" but it still sounds good and gets the job done. Lately, however, my sub has been sounding somewhat "bass heavy" and I'm not sure why. I have the sub connected to the Marantz's sub-out, which, as far as I know, is full range, going into the LFE input on the sub. As per Velodyne's instructions, I'm now using the sub's internal crossover, since the sub's "direct" input is for coming from another crossover, which I'm not using; however, the instructions in the Marantz manual says that with a sub which has a "direct" mode, to use that one by disabling the sub's volume control and the crossover frequency. Correct me if I'm wrong, but if I disable the sub's volume control, I assume by turning it down all the way, how will any signal be reproduced so one can hear it. Also, the only crossover control on the sub is the "low pass", so would this need to be set at minimum? Am I "over-thinking" all of this?
Any advice or suggestions would be appreciated, especially from a Velodyne user. Thanks!
