Anyone know MS Word really well?
Discussion in 'After Hours Lounge (Off Topic)' started by MikeM, Jul 14, 2005.
  1. MikeM
    MikeM Screenwriter
    Nov 23, 1999
    1,203
    I just need help with what appears to be an easy task, but I can't figure it out. I need to do a Find/Replace on a Word document, for all the instances where there are soft returns (shift-return).
    I have the View > "Show Paragraph Marks" ON to view the marks, and I can visually see the soft-return marks and delete them manually. But this is a huge document. I need to find/replace, but I can't seem to know what to enter in the "find" box for the exact character for a soft-return. I tried "^n" and "
    " (no quotes) but no luck.
    Anyone know the charater for a soft-return that I can enter in the find/replace box? Thanks.
  2. Marko Berg
    Marko Berg Supporting Actor
    Mar 22, 2002
    857
    This should be in the Computers and HTPC area, but here goes:
    In the Find and Replace dialogue box, click the More button, then the Character button. Apparently there are two types of manual line breaks, ^l and ^m. See if replacing these with nothing will help.
  3. MikeM
    MikeM Screenwriter
    Nov 23, 1999
    1,203
    oops...sorry, I guess this should be in Computers....
    THANK YOU!!
    It was "^l"!! That did the trick. Thanks again!
