Anyone know ASP Code?
Discussion in 'Computers' started by Brett Hancock, Jun 5, 2003.
  1. Brett Hancock
    Brett Hancock Supporting Actor
    Jun 17, 2001
    922
    All I have to do is make a survey that the user can fill out and then there answers will be written to a database or text file. I figured I would use ASP sense that seemed to be the easiest way to do it from the people that I talked to. I was just wondering if anyone would care to help me do this or give me a few resources to look at to help me along, sense I need to have it done bye Saturday and I have no idea what to do. This would be a huge help and I would appreciate it a ton. Thanks.
  2. Shane Bos
    Shane Bos Second Unit
    Jun 15, 2002
    256
    yeah an ASP front end with an Access back end would work for it. Sorry I have forgotten all the ASP I used to know.
  3. Simon_Lepine
    Simon_Lepine Supporting Actor
    Feb 19, 2003
    601
    You should do the tutorial on this site, it's very well done and should help you:
    http://www.w3schools.com/asp/default.asp
    You should use ADO to connect to a database, there is a turorial for that after the ASP one
    Hope this helps
  4. Simon_Lepine
    Feb 19, 2003
    601
    Wanted to add, if you don't want to get into anything complicated and you feel you can compile your survey yourself, you can have a form submission be e-mailed to you
    ,like it's explained in this page:
    http://home.att.net/~knoblock/mailto_forms.html
  5. Vince Maskeeper
    Vince Maskeeper Producer
    Jan 18, 1999
    6,499
    Doing the form > database thing is uber simple. You could write this code in 30 minutes. I'd probably be willing to help out, depending on how in depth you wanna go.
    I think any ASP for dummies book would have a tutorial on this type of stuff, if you wanna learn the language.
    -Vince
    PS: This forum does have a computer area, where something like this might have gotten more attention.
  6. Max Leung
    Max Leung Producer
    Sep 6, 2000
    4,611
    As was mentioned there are a lot of simple ASP tutorials. And, if you're using the latest and greatest tools, ASP.NET tutorials all over the place too (google helps). Hmmm, maybe check out www.codeguru.com , I think they will have a full range of tutorials and useful sample code for Visual Studio .NET, Visual Basic, and Visual C++.
    I go there if I need to do complicated GUI work.
