Anyone know anything about the mits 80803 from 1999
Discussion in 'Archived Threads 2001-2004' started by Rick R, Nov 27, 2001.
  1. Rick R
    Rick R Auditioning
    Mar 15, 1999
    2
    it is an 80 inch hdtv ready rear projection that i can maybe get for 4000.00..store demo but seldom used....list was around 9000.00.....if anyone knows if it is a good or bad set can you let me know.....i cant find any reviews about it...thanks....rick
  2. Rick R
    Rick R Auditioning
    Mar 15, 1999
    2
    i just found an old review from sound and vision last year....it said that this 4-3 set cant fully display enhanced 16by 9 dvds..it cuts off 25 percent of the image...is this real bad,,,enough of a problem to avoid buying the set..i mainly watch satellite anyway but we do have a bunch of dvds....thanks...
  3. Bill_M
    Bill_M Agent
    Aug 8, 1998
    41
    Is it HD capable? If it is, it probably only squeezes a 1080i signal. Make sure the new Mits or another brand HD-STB is compatible with it. Yes you probably won't be able to display anamorphic DVDs on it with out setting the DVD player to letterbox on 4x3 sets and losing 33% of the resolution.
