Anyone know a "shelf" to lift up the tv?
Discussion in 'Archived Threads 2001-2004' started by Allan, Nov 26, 2001.
  1. Allan
    Allan Stunt Coordinator
    Oct 1, 2000
    205
    For the bedroom, the tv must be on a relatively low stand. I really could use a shelf of some sort to place on the stand (under the tv) to prop it up. 6 inches would be great. Additionally, I would love if there woudl be room under the shelf for a componenet (either the cable box, vcr or center channel speaker).
    A quick picture might help illustrate what I am looking for:
    TV
    -----STAND-----
    For some reason, the picture will not come out correctly -- the right side of the shelf should be on the right border of the tv.
    Any suggestions??? I should probably add that the tvis a 19 incher.
    thanks,
    allan
  2. Bobby T
    Bobby T Supporting Actor
    Mar 13, 2001
    583
    I built what your talking about for $25 in materials and by no means am I any kind of carpentar.
  3. Allan
    Oct 1, 2000
    205
    Good point Bobby, but being in NYC, I do not have access to tools and/or lumber. I am really just looking for something the right size and shape (preferably in black) that I could use.
    allan
  4. PomingF
    PomingF Second Unit
    Mar 4, 2000
    343
    Allen, years ago I bought a plastic swivel TV/VCR shelf to raise my 19" TV off the top of the dressor while keeping the VCR inside the bottow slot. I am sure places like J&R still sell them.
    PF
  5. DougRuss
    DougRuss Stunt Coordinator
    Oct 3, 2001
    195
    Found this unit, it may be what your looking for?
    TV Shelf
  6. Chad Isaacs
    Chad Isaacs Supporting Actor
    Feb 20, 2000
    757
    Well,I am cheap when it comes to this kind of stuff.Why not get a couple bricks for each side.Paint them black or wrap them with black material.Use a shelf board and viola
  7. Allan
    Oct 1, 2000
    205
    Doug,
    that is exactly what I am looking for. If anyone can find somehting similar that is a bit cheaper, that would be even better. Also, if anyone knows that exact measurements of the Sanus TT30 that Doug pointed out, that would also be helpful.
    Allan
  8. PomingF
    PomingF Second Unit
    Mar 4, 2000
    343
    Allan, jandr.com has similar swivel TV/VCR shelves for less (both $ & TV size). The one I have is basically the same except it's made out of black hard plastic and accommodates my 19" TV fine. Of course it costed me slightly less than $40 even back 5 years ago. [​IMG]
    PF
  9. Allan
    Oct 1, 2000
    205
    Doug-
    I jsut wanted to let you know that I purcahsed the Sanus unit. Unfortunately, the one pictured in you link did NOT include the VCR shelf (it was merely a turntable) but the newer version turntable had an optional VCR "kit" to add such a shelf. I bought it a week ago and got it yesterday and it is perfect for what I was looking for!!
    Thanks again,
    Allan
  10. Bill Johnston
    Bill Johnston Stunt Coordinator
    Nov 20, 2001
    77
    How big is the TV? Maybe 2-3 glass blocks on each side, then get a couple of peice of plywood or have the lumber yard cut to size... and then, use silicome to hold eveything together...
    This would kind of look neat... Depending how heavy your tv is...
    Bill
