Anyone heard the Linkin Park: Reanimation DVD-A?
Discussion in 'Archived Threads 2001-2004' started by Travis Olson, Mar 14, 2003.
  1. Travis Olson
    Travis Olson Supporting Actor
    Oct 7, 2001
    937
    Travis Olson
    I was thinking about getting this disc, but would like to know if it's good or not. Anyone heard it? How's the surround use and bass?
  2. Dan Joy
    Dan Joy Supporting Actor
    Dec 8, 2001
    758
  3. Travis Olson
    Oct 7, 2001
    937
    Travis Olson
    Thanks Dan, thats kind of what I thought but couldn't find any reviews for it. I don't have and ICBM so I can't hear DVD-A bass as was intended, which really sucks. But I do have an Acoustic Research ARS-500 and it has handled everything I've thrown at it with authority. [​IMG] I'll have to pick it up.
  4. Dan Joy
    Dec 8, 2001
    758
    Travis, Just becareful with your center channel. There is an awful lot of bass there too!
  5. John-Miles
    John-Miles Screenwriter
    Nov 29, 2001
    1,210
    I have the disc, and well i Loved hybrid theory, but i cant stand this one, the remixing is pretty heavy, the original songs are not really well represented by this, but if you are into remixing then you will probably like it.
  6. Seth_L
    Seth_L Screenwriter
    Apr 5, 2002
    1,553
    I've only heard the Dolby Digital 5.1 version of the disc. It has a lot of bass, but because it's DD5.1 my reciever's bass management still works so my speakers aren't at risk.
    Travis,
    Listen to it using the DD5.1. Then your bass management will work just fine. I think the disc is only at 48/24 anyhow. You're probably not losing much listening to the DD5.1 version.
    Seth
  7. John-Miles
    Nov 29, 2001
    1,210
    Ah but DD isn't even as good as CD, and 48/24 is still better than cd.
  8. Seth_L
    Seth_L Screenwriter
    Apr 5, 2002
    1,553
  9. LanceJ
    LanceJ Producer
    Oct 26, 2002
    3,168
  10. John-Miles
    Nov 29, 2001
    1,210
    Well DD is ALOT more compressed than a cd, the compression has to hurt the quality. I mean think about it DD is more compressed than DTS, and DTS can fit 5.1 channels on a cd while a cd can only fit 2 channels on a disc, so DD has to be allot more compressed, and at its best cd is 44.1kHz and 16 bit which is noticably less than 48/24.
  11. Dan Joy
    Dec 8, 2001
    758
    I feel that the 48/24 is significantly better than the DD. Plus, why listen to DVD-A discs with an appropriate player on DD(yes, I know about the bass mismanagement)[​IMG]
  12. Seth_L
    Seth_L Screenwriter
    Apr 5, 2002
    1,553
  13. John-Miles
    Nov 29, 2001
    1,210
  14. Seth_L
    Seth_L Screenwriter
    Apr 5, 2002
    1,553
  15. John-Miles
    Nov 29, 2001
    1,210
    Thanks for the explaination Seth, but I really do ahve to disagree, you CANNOT get more than what you put in.
    its like having a number 10.000001 thats the original, it gets compressed to 10.0 because of space constraints, and who notices the 00001. so then you use some fancy algorithm to recreat 10.000000008 yep it sure does ahve more detail there, more bits longer more PRECISE number, but its not more accurate and really accuracy is what you want.
    and I havent listend too reanimation much, but i can gurantee you that I hear a huge ammount more detail in my Metallica Black album on DVD-A and CD than i do in DD
  16. Seth_L
    Seth_L Screenwriter
    Apr 5, 2002
    1,553
  17. RobBenton
    RobBenton Stunt Coordinator
    Mar 21, 2003
    159
    anyway DD 5.1 might be good at compression but compression is still compression and especially when something is compressed that much you loose quality. the DVD-A track is noticably better then the DD track.
