anyone have the Toshiba 32HF72?
Discussion in 'Displays' started by david*mt, Jun 22, 2003.
  1. david*mt
    david*mt Second Unit
    Dec 11, 2002
    306
    Is it worth the $899 that Bestbuy is selling it for? I'm looking for something good for DVDs and can't spend more than $1000. I would appreciate any comments. Thanks
  2. Matt Lee
    Matt Lee Agent
    Jun 9, 2003
    47
    I've been considering that set myself. Seems like a good price at $899, but that's because its on clearance. What I've been wondering is whether its worth it to spend the extra few hundred on the new toshiba 32" 32HFX72. I've only seen them in stores, frequently with bad signals, so its not 100% reliable, but in a few instances it seemed like the new model, the 32HFX72 looked a bit better than the 32HF72. Its a cinema series, but it doesn't appear to have a DVI input, and I know the 32HF72 doesn't. The new model is going for about $1399 I think.
    Anyone know what the big difference is between these, besides $500, if there is one?
  3. Blaine Skerry
    Blaine Skerry Second Unit
    Aug 15, 2001
    277
