Anyone have info on ELF1.0 kits
Discussion in 'Home Theater Projects' started by Kevin Patterson, Apr 5, 2004.
  1. Kevin Patterson
    Kevin Patterson Stunt Coordinator
    Jan 14, 2004
    61
    I am looking for a cheap but good hometheater i was previousely looking at the dayton diy speakers that are around 100$ per pair an i have seen the ELF1.0 kit for 100$ i am wondering what this includes besides drivers an has anyone heard them are they worth it an what are some other sudgestions on diy low cost speakers for ht.
    Kevin
  2. Aaron Howell
    Aaron Howell Stunt Coordinator
    Nov 19, 2003
    196
    FWIW, I havn't heard either, but while browsing the other day I did notice creative sound has the elf 1.0 home theater kit for $135usd + shipping.
  3. TimForman
    TimForman Supporting Actor
    Dec 4, 2002
    847
    In the basic kit you get a driver, a port tube, input cup, sealing caulk and screws. The W3-871S is a fantastic driver for it's price. Keep in mind that the Elf 1.0 rolls off quite high which means your sub will need to XO at 100 or 120 Hz. If you only have $100 I don't know of a better way to go. If you have a little more $ you may want to look for mains that can go a bit lower.
  4. Kevin Patterson
    Jan 14, 2004
    61
    On the creative sound website it said 100$ for 5 Kits and i was just wondering whats in those kits also can anyone reccomend some other nice ht speakers on a budget my budget is around 300-400$ canadian i will probably spend more but can someone at least sudgest a diy bookshelf for under 100$
    Kevin
  5. TimForman
    Dec 4, 2002
    847
    The SuperElf would fit that description.
