Art Morales
- Dec 16, 1998
My wife has her heart set on pulling up the carpet and installing laminate flooring like Pergo. Does anyone have any experence good or bad with laminate flooring? It looks pretty easy to install your self. Glued, pre-glued, or snap together? I was told that if you have some damage with the glued type the only way to replace a plank is to cut it out as opposed to taking the floor apart and replacing the damaged plank and putting it back together with the snap type. Or should I talk her out of it and buy a HDTV
