Anyone familiar with automotive electrical systems?
Discussion in 'After Hours Lounge (Off Topic)' started by SteveLa, Sep 1, 2004.
  1. SteveLa
    SteveLa Stunt Coordinator
    Mar 30, 2004
    76
    I have a 1999 Chevrolet that recently exhibited a problem with the heating and a/c system. Basically, the fan has four speed settings and for some reason, it only turns on when set to the two highest speeds. If I try setting it to the two lowest levels, the fan doesn't turn on at all. Is there some sort of sensor or switch that controls the fan and is it something I would be able to replace or would I need to take it to the pros? Is it possible that it's a fuse that's bad? Any advice is appreciated.
  2. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    On other cars I've owned they have something like a resistor pack between the switch positions and the fan motor that varies the voltage to the motor, this is probably similar to your problem, the middle settings on this particular car liked to blow, but I'm not familiar with chevys. Plenty around here are though.
  3. Julian Reville
    Julian Reville Screenwriter
    Aug 29, 1999
    1,195
    I had a 1985 Chevy Blazer; does that count? [​IMG] If it's not the switch it may be the fan itself. The heating & a/c fan on mine started running slower and slower.....eventually made this awful screech and died. Luckily it was easy to replace, being mounted on the firewall and looking like an encased fan; I can't even find the fan on my Montero Sport.
  4. Zen Butler
    Zen Butler Producer
    Jan 24, 2002
    5,536
    18
    Southern, Ca
    Zen K. Butler
    Philip is in the right neighborhood. It is most likely a blower resistor. The lowest settings having the most resistance to lower the speed. These go out first.
    Climate control heads are also a common problem on pre-mid-99 Chevy. I'm going with the resistor in this case though.
  5. ClintS
    ClintS Stunt Coordinator
    Nov 26, 2003
    169
    I had a similiar problem on a dodge, it was a Thermistor Relay. Dont know if that helps or not but it was a very similiar problem.
