anyone ever retrofitted a bathtub to a walk in shower?
Discussion in 'After Hours Lounge (Off Topic)' started by Philip_G, Mar 27, 2005.
  1. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    So, the house that is still being built and I won't close on until early may.... I noticed one of the other houses had a nice walk in shower in place of a tub in the master, I wish I had considered this (I really didn't even know it was an option)
    so, I'm thinking it wouldn't be so bad to get something like this
    http://www.theswancorp.com/products/...ofit/index.php
    http://www.faucet.com/decor/product.pl?mid=9167
    Re-plumb the faucet up higher, throw in some backer board and tile around it. I wanted to yank out the plastic surround and add tile anyway.
    Am I crazy? Is this harder than it seems? 200 bucks for the base, maybe another 100 for tile, and a couple hundred for a glass door seems pretty reasonable, and I can get a matching silestone counter top later if I want.
  2. Justin Lane
    Justin Lane Cinematographer
    Jan 18, 2000
    2,149
    Philip,
    Have you priced Swanstone? If you go that route it is going to be a bit more expensive then you are budgeting. I recently helped my father re-model one of his bathrooms, and the swanstone around the new tub ran about $800. If you are also going with a swanstone floor and largish glass doors, you will probably be spending in the $1200-1500 range (or more)which is a $1000 bucks over what you have budgeted.
    Looked at your website and the shower walls are almost $1000.
    http://www.faucet.com/decor/product....27302&fh=White
    Of course you could go ceramic tile for the walls and cut down on the costs some, if you feel comfortable doing your own tile work.
    As for installation, it all depends on if you can find a base which has the same footprint as your tub. If not, you are probably going to end up with some modifications to your flooring which may or may not be easy.
    J
  3. Jeff Ulmer
    Jeff Ulmer Producer
    Aug 23, 1998
    5,584
    I would find it hard to imagine tiling a walk in shower for $100, unless you are using really cheap tile. Glue and grout alone could run you half that.
    The biggest issue is getting the thing watertight. Your budget will go up exponentially if there are leaks anywhere in the system.
    Also, does the house have another bath tub? The lack of one will hurt resale value, at least it does around here.
  4. Richard Travale
    Richard Travale Producer
    Feb 27, 2001
    3,425
    12
    The Island, Canada
    Rich Travale
    Also, think about getting the old tub out of the room. It may not fit through the doorway.
    This is usually why the contractor brings the tub in before the walls are up.
  5. Jason Kirkpatri
    Jason Kirkpatri Second Unit
    Jan 6, 2002
    389
    For the tub going out of the doorway - cut the tub in half and it'll fit! The tub is lost, but that's the way it goes sometimes.
    I prefer tile over and pre-made walls. I am going to have to pull my walk in walls down and tile. Easier to keep clean, IMO.
  6. Mike Voigt
    Mike Voigt Supporting Actor
    Sep 30, 1997
    799
    Any chance you can get the builder to change at this time? If the drywall is up, probably not - but if they have roughed in the piping, and still not installed that stuff, you may be able to get away with it.
    Or at least leave it unfinished so you can do what you need to. Use one of the other bathrooms in the house in the meantime...
  7. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    Oh man. lots to reply to.
    Oh hell no. I made all my choices last september and they didn't start construction until late january, even before construction they wouldn't make changes, certainly not now (and yes the d/w is up..)
  8. Ryan Wishton
    Ryan Wishton Screenwriter
    May 17, 2003
    1,130
    I like the idea of a walk in shower seperately from the Whirlpool.
    A combined Whirlpool Tub/Shower can be a pain in the ass. This is what he have. Too deep to be climbing in and out of all the time for regular showers (especially when someone is tired as it is). Someone might break a hip.
    Would never want to go without the tub (The motion of the water serves it's purpose for certain events). But, would definately prefer the shower seperately where it's not like climbing stairs to get to it.
  9. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    I don't have enough room for a shower AND a tub in this w/c, so I'd rather just forgo the tub and put a shower in...
    the builder had an option for a big garden tub but it just looked way too much of a PITA to use daily.
