Anyone else seeing a delay in the HD pack?
Discussion in 'Archived Threads 2001-2004' started by Scott FP, Nov 21, 2001.
  1. Scott FP
    Scott FP Agent
    Nov 12, 2001
    39
    I ordered the HD pack online from Best Buy back on 11/13, it has been "backordered" ever since. My Xbox is already here and that took less time!
    Have you seen the HD pack in stores? Would I have more luck to just go to Best Buy and see if I can pick one up and return my order? Or do you think there is a shortage of HD packs?
  2. James D S
    James D S Screenwriter
    Nov 14, 2000
    1,000
    Scott, Here at the Best Buys in town the standard HD pack is staying in pretty good stock. The Advanced pack, however, comes and goes pretty quickly. Check it out though.
  3. Scott FP
    Scott FP Agent
    Nov 12, 2001
    39
    Thanks James,
    Should have clarified, I was referring to the the Advanced pack. I have component avail. on my Sony Wega. I know it won't take full advantage of the Advanced pack but it should be better then using the RCA jacks.
    I'll just keep waiting for Best Buy to ship...
