Anymore info. on the new Panasonic DVD players?
Discussion in 'Playback Devices' started by David Judah, Apr 7, 2004.
  1. David Judah
    David Judah Screenwriter
    Feb 11, 1999
    1,479
    Specifically, any info about the DVDS-97S(video DAC, deinterlacer, MPEG decoder)? I read a press release during CES about them but there was nothing specific.
    I have a Technics DVD-A10 in for repair, and the warranty company has decided it's not economical to fix, so they are replacing it with a 97S.
    It's for a bedroom system, but if it ends up being better than the RP-91 that's in my main system now, I'll switch them out.
    Of course, I'll end up A/B'ing them when I get it, but I'm curious if anyone has any inside info. about specs and release date?
    DJ
  2. David Judah
    Feb 11, 1999
    1,479
    No one has heard anything?
    DJ
  3. Clayton Jr
    Clayton Jr Extra
    Jan 13, 2004
    17
    I couldn't find anything on the Panasonic website about new models.
  4. Rob Kramer
    Rob Kramer Second Unit
    Mar 30, 2004
    435
    Re DVD-S97
    Had mine pre-ordered from amazon for a LONG time now. Maybe someday.
  5. JohnnyG
    JohnnyG Screenwriter
    Dec 18, 2000
    1,522
    216Mhz, 11-bit DAC
    720p & 1080i upconversion (via HDMI)
    Faroudja DCDi
    No mention of the MPEG2 decoder (which is hardly unusual though).
  6. Jim-M
    Jim-M Second Unit
    Oct 22, 2001
    266
    The Panasonic S97 won't have Faroudja DCDi according to this post.
  7. JohnnyG
    Dec 18, 2000
    1,522
    In the catalog I just got from Panasonic Canada, it definitely does state:
    "DCDi - Directional Correlation Deinterlacing by FAROUDJA"
    The emphasis on "Faroudja" is theirs.
  8. David Judah
    Feb 11, 1999
    1,479
    Thanks for the info. guys. I'm curious about how much difference there will be for movies, but I'm sure it will outperform the RP-91 for video based material(I do have alot of concert DVDs). Hopefully, it'll be in soon.
    DJ
  9. Jason GT
    Jason GT Second Unit
    Dec 12, 2002
    452
    Ugh, I hate to ask this, but...
    JohnnyG, how is HDMI compatible with DVI? I understand that HDMI simply has extra leads for audio, and can be adapted to DVI with an adapter?!
    The Panasonic could be quite decent, as I'm looking for a player that will do 720p upscale through DVI (to Samsung DLP). yes, I've tried the HD931 and had issues, and I understand the LG unit has a severe DVI problem... so maybe it's trusty old Panasonic ?!
  10. JohnnyG
    Dec 18, 2000
    1,522
    That is correct. Either a simple HDMI->DVI adapter on an HDMI cable, or a cable with an HDMI connector on one end, and a DVI connector on the other. Like you say, there will be no audio from the DVI end, but the S97 still has 6 channel analog, as well as both optical and coaxial digital audio outputs.
  11. matt-f
    matt-f Second Unit
    Aug 8, 2003
    267
    Panasonic Canada's release date for DVD-S97 is September 2004.
  12. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    No 5 disc version?
    The S97 will have an output you can connect to the DVI input of a projector (after using adapters or proper cable)?
  13. JohnnyG
    Dec 18, 2000
    1,522
    Sadly, no. And just after I praised them last year for finally getting it right and offering a 5 disc changer version of each single disc model.
  14. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    Where can I find out more about this player? Will it have aspect ratio control? I do use the iScan Ultra now, and as I've mentioned, its handy for NTSC cable, digital cable, SVHS and LD (although I've no LD anymore)...but if there was a good standalone with Faroujda with aspect ratio controls and the other useful noise reduction and other handy features that Panasonic is known for, the S97 may be a good bet. Depends on price etc. Otherwise, I'll go for an F87 and use it with my iScan Ultra. Wish I could do SDI to it and the iScan Ultra. The iScan HD does SDI after its modded but its too much $'s for me.
  15. Jay Blair
    Jay Blair Second Unit
    Nov 3, 2001
    333
    Chris, do keep in mind that you can trade your Ultra in on the HD for a $500 credit, which is what I did, not that it is exactly cheap even at that.
  16. David Judah
    Feb 11, 1999
    1,479
    I've been looking for info. on the player ever since I found out it was going to be my warranty replacement, Chris. Unfortunately, there is only a blurb from CES, which at that time had it listed for an April release. The only other info. I've got is the stuff Johnny mentioned here in this thread. The CES stuff is here. It's a short few sentences that is the third paragraph down.
    When I can, I'm going to get the SA-XR70 receiver to mate up with it, since it has HDMI--I want to see if it'll make that much difference for DVD-A. I'm curious too about those Panasonic digital receivers in general. They've actually been getting some good reviews with some raving about them when used with digital sources. Some have even suggested at Audio Asylum that the amp section is comparable with some high dollar analog amps.
    It should be interesting.
    DJ
  17. Chris PC
    Chris PC Producer
    May 12, 2001
    3,975
    The trade up is an option, but still too rich for me right now. When I get a higher resoluton Projector, I'll going to let the PJ scale for now and see how it looks.
  18. Jonathan Dagmar
    Jonathan Dagmar Supporting Actor
    Dec 29, 2002
    723
    Quite frankly I think they outclass any analog of any price when it comes to playing digital sources, be it DVD, CD over a digital connection, and so on, and they aren't have bad with analog sources either.
    This is the future of amp technology.
    My only complaint is that they skimp on the speaker terminals, only offering binding posts on the front channels.
    I have owned a digital AMP, and will never go back to analog, ever. Theese little amps are that good. I just wish Panasonic would release a higher end model, fuixing things like the speaker terminals and oother minor details.
