I've had a few. Currently I'm using a Jornada 568, which is a great piece of hardware. It's going on Ebay this week though. New models coming out soon, gotta clear the decks and get ready.
Currently still using my trusty old Casio E-125 every single day, and it works just fine. A bit on the heavy side, but solid... it has had a couple unfortunate run-ins with the floor so far and no problems whatsoever.
I'm about to trade up to the new Fujitsu-Siemens Pocket LOOX (I didn't name it ) though, with the phone addon. Always-on network access and phone functions in one box, with the new Intel XScale 400mhz cpu in it too... woohoo.
i've got a maestro too... but one with a cracked screen :frowning:
hopefully audiovox will take care of it under warranty.
as far as the xscale stuff goes, it's looking pretty good.
the best sites to find ppc info are (imnsho): Link Removed www.pocketpcthoughts.com www.mobigeeks.com/e www.brighthand.com
-gary
Don't have any Xscale sites offhand, but it's essentially a Strongarm CPU (100% compatible) but with much improved power management. It scales CPU power up and down depending on load... maybe that's where they found the name, who knows.
If 400MHz is required it goes to that speed, but when idle it slows down.
At least that is what I have picked up via the net. Doesn't have to be 100% accurate.
The new Fujitsu-Siemens is supposedly going to have a minimum of 12 hours of non-stop usage time out of the box, which is pretty darn good. With occasional usage (like most people do, much less than 12 hours a day) it should last days between recharges.
