Anybody know stirling engines?
Discussion in 'After Hours Lounge (Off Topic)' started by David_Moechnig, Apr 28, 2004.
  1. David_Moechnig
    David_Moechnig Stunt Coordinator
    Dec 10, 2002
    122
    I just got done building a stirling engine for applied thermodynamics and thought that maybe someone here would be interested in seeing it and give some critiques/advice. I haven't run it yet, waiting for some JB Weld to cure then I'm going to put the heat to it and see if it will go. More pictures can be found at: http://www.umr.edu/~moechnig/ME221/pictures
    [​IMG]
  2. Philip_G
    Philip_G Producer
    Nov 13, 2000
    5,030
    very cool!
    'fraid I don't know very much about them though.
  3. Scott Strang
    Scott Strang Screenwriter
    May 28, 1999
    1,145
    4
    I've always wanted one of those. What will be your heat source?
    I had a small steam engine when I was little and it was really cool.
  4. David_Moechnig
    Dec 10, 2002
    122
    The heat source will be a sterno can. The assignment was to design and build an engine that buts out .5-1 watt using sterno at a heat source. We test them tomorrow, I'm looking forward to seeing how close to the desired power output I am.
  5. Lance Nichols
    Lance Nichols Supporting Actor
    Dec 29, 1998
    726
    Hmm, I was thinking for my next case mod to use some heat pip on either a graphics card, or my CPU to power a sterling engine that would then power chimney fan on the case...
    Likely switch to water cooling though, too much noise.
