Any word on a budget yamaha DPLII receiver?
Discussion in 'Archived Threads 2001-2004' started by Jason Wilcox, Feb 22, 2002.
  1. Jason Wilcox
    Jason Wilcox Supporting Actor
    Feb 21, 2002
    652
    Any word on a budget yamaha DPLII receiver? less than $400
  2. David Judah
    David Judah Screenwriter
    Feb 11, 1999
    1,479
    I think I remember seeing Pro-Logic II as a feature on the spec. sheet of the RX-V530. It will be out soon and will retail for $400.
  3. Jason Wilcox
    Feb 21, 2002
    652
    Thanks!!! That's the best news I've heard in a long time. Do you know if you can adjust the LFE crossover with those Yamamha receivers? Is that a common option with budget yammys?
  4. Jason Wilcox
    Feb 21, 2002
    652
    like on the htr series?
  5. MatthewJ S
    MatthewJ S Supporting Actor
    Feb 27, 2001
    584
    DOUBT IT......LIKELY FIXED AT 90HZ, TOO BAD....
