Any way to fix a small scratch on a television screen?
Discussion in 'Archived Threads 2001-2004' started by JasonRH, Jul 14, 2001.
  1. JasonRH
    JasonRH Second Unit
    Jan 8, 2001
    496
    I got a brand new Wega last week and I noticed a small scratch on the screen. It's probably 1/2 to 3/4 of an inch long and is probably not affecting the picture in the area. Still, it was delivered like this so I was wondering if there was a way to fix it or would they have to replace the entire screen? Thanks a lot.
  2. JasonRH
    JasonRH Second Unit
    Jan 8, 2001
    496
    does anyone know if this can be fixed? Anyone?
  3. Ryan Pream
    Ryan Pream Stunt Coordinator
    Feb 11, 1999
    86
    If it bothers you then they will probably have to replace the TV.
    Ryan
  4. JasonRH
    JasonRH Second Unit
    Jan 8, 2001
    496
    Agreed, they would relace it but it is the third set and it's becoming a real nuisance carting these heavy things back and forth to and from the dealer (others had bad geometry problems). I'm probably being overly picky about the scratch but I thought there may be a way to hide it without replacing the entire screen or exchanging the set. Any ideas?
  5. Ryan Pream
    Feb 11, 1999
    86
    If it's very faint there is glass polish for cars that might take it out. It might also make it look worse. Then they could blame you and not take it back at all.
    Ryan
  6. JasonRH
    JasonRH Second Unit
    Jan 8, 2001
    496
    Thanks Ryan, I'll check into it.
