Frank Lee
- Nov 27, 2002
My Infocus 4805 is on the way. I realized today I need a way to plug it in. I would like to install a new duplex outlet in the ceiling, but it will be very difficult to do because of pre-existing finished walls and ceiling. For running my component video cables I was planning on using one of those plastic wire channels that has a paintable cover. Could I run a electrical cord inside that with the component cable? I am guessing that will cause serious interference. I just wanted to check because that would be the easy way out. What are you guys doing to get power to your projector?
