I am considering creating a HT room in a cornner of my basement. The room can be about 9' wide by 18' long and is about 86" from the concrete floor to the floor joists above.
Two walls are the exterior concrete the current rear wall is just a standard 2X4 stud wall with drywall.
I am thinking of doing a wall along the length of the 2X10 support beams, and making the wall a 2X6 staggered stud construction. Or since I wasn't planning on doing anything with the ceiling and the back wall is a normal 2X4 wall will this not matter?
Here are some images of what I have to work with.
This is an image of the dividing wall and the floor joists.
//al_e.home.mchsi.com/resized/basementstart002.jpg
This image is of the water lines that run below the floor joists on one side of the room.
//al_e.home.mchsi.com/resized/basementstart005.jpg
This image is a view of the area from the front to the rear.
//al_e.home.mchsi.com/resized/basementstart003.jpg
I guess the direct linking to images is not allowed since I don't have 15 posts. Please cut and paste the links if you would like to see the images.
Al E
Al E
