any SVS CS owners try this for amplification???
Discussion in 'Archived Threads 2001-2004' started by rodneyH, Sep 20, 2001.
  1. rodneyH
    rodneyH Supporting Actor
    May 22, 2001
    844
    I am seriously considering a SVS subwoofer, but my only question is this. Since I don't want to use a normal amp to power the sub, could I just buy a sub amp/crossover (adire audio has a fairly good deal on a 250W) and screw it on the back of the SVS cabnet. it is 10" wide (and a flat shape) so it may stick out a little (even if I turn it towards the back), has anyone else tried this???
  2. Ryan Schnacke
    Ryan Schnacke Supporting Actor
    Feb 5, 2001
    876
    You might just make a separate box to house the plate amplifier and then hide it behind your SVS.
  3. Jack Gilvey
    Jack Gilvey Producer
    Mar 13, 1999
    4,948
    I really don't see how that would be an advantage over buying a PC model, although it should work. And "screwing it" onto the back of the sub is not to be taken lightly, you're screwing into a cardboard cylinder.
    If you really needed an amp on the cheap for an SVS, grab a http://www.partsexpress.com/pe/pshowdetl.cfm?&PartNumber=300-800&DID=7
    [Edited last by Jack Gilvey on September 20, 2001 at 08:28 AM]
  4. BryanZ
    BryanZ Screenwriter
    Dec 18, 2000
    1,214
    110
    Don't screw the amp into the CS. Put it in a separate box. You can then run speaker wires from the amp to the sub without ruining the looks and sound of the sub.
  5. rodneyH
    May 22, 2001
    844
    The parts express looks like a good alternative. When you mention cardboard, ARE YOU SERIOUS??
  6. Lewis Besze
    Lewis Besze Producer
    Jul 28, 1999
    3,134
    Yep!
    "You Hungarians always disagree"
  7. jeff peterson
    jeff peterson Supporting Actor
    Nov 29, 1998
    675
    Actually, I think it's fiberboard. The original SVSs were made from Sonotube (those construction tubes used to make cement cylinders), now they have a proprietary tube.
  8. Ron Stimpson
    Ron Stimpson Stunt Coordinator
    Jul 19, 1998
    199
    Rodney,
    Our custom drawn, polymer-wrapped, tubing has about as much in common with "cardboard" as a hotdog does with a racehorse...
    Both can be eaten in a pinch, both are (or were) "meat"; and both are longer than they are tall.
    I'd say that covers it. Even "Sonotube" is similar only in concept. Very different material, made in different way and to our exacting specifications. You might as well call MDF (medium density fiberboard, which many speakers use for enclosures) "dried wood-dust paste".
    On power, put an amp in a small box, tuck it away in your HT and you'll have a great budget way to power a CS sub. Take a look at pictures of our PC line however and I think you'll see that strapping on a standard plate amp to one of our subwoofers is impossible. I'd rather see you get a nice used box amp, or even a $80 KLH receiver from Best Buy (they work great for sub power!) than cut into a new SVS.
    Don't go there please.
    Ron
    [Edited last by Ron Stimpson on September 21, 2001 at 07:48 PM]
  9. Jack Gilvey
    Mar 13, 1999
    4,948
    Right, sorry for generalizing. Since I know what a good material such a tube is for a sub, I didn't see people taking it in the wrong way. Whatever it is, it obviously works extremely well in its application. I was referring to Sonotube, which I was under the impression was the material used according to the Nousaine review. Bottom line, though: don't try to screw into it.
    That's an accurate description of MDF, though. [​IMG]
    [​IMG]
    [Edited last by Jack Gilvey on September 21, 2001 at 07:33 AM]
