Any suggestion on color code Canare connectors (1 Viewer)
Yi Yin
Grip
I recently built some DIY belden canare cables. I am looking for the best way to color code them (red/blue/green/orange/white etc). I've tried colored canare boots, however they don't fit the techflex i have on the cable. Colored heatshrinks are nice. Are there any other alternative out there? thanks!
Yi
Stephen Hopkins
most hardware stores sell colored electrical tape. A single wrap around the crim collar would look pretty good, especially if cut to be the exact same width as the crimp collar.
Yi Yin
Grip
You are right, electrical tape would be a good way to do it. Any other ideas? keep'em coming. thanks guys.
Yi
MJL
