Any SAS Programmers Out There ?
Discussion in 'Archived Threads 2001-2004' started by Alex S, Jan 23, 2002.
  1. Alex S
    Alex S Second Unit
    Feb 21, 2000
    477
    A vendor sent me a file with numeric fields that he wants reports generated from.
    The first report he wants me to add 2 numeric columns up for over 250,000 accounts.
    An example of how the data is displayed is like this:
    0000000001817.86
    -000000000071.34
    The sign and decimal point is in the data.
    Can this be done by a SAS program ?
    If so how ?
    Thanks.
    Alex S
  2. Dave Morton
    Dave Morton Supporting Actor
    Oct 19, 2000
    753
    Dave
    Alex,
    I've been programming in SAS for 10 years and yes, you can do that. SAS will discard the preceding 0's or else it will think the column is character and you have to change it to numeric by adding a 0. So your code would look like this:
    newvar=oldvar+0;
    Then to sum up the columns you can use the following to create a data set called final with a variable called col1sum and col2sum for the sum of each column;
    proc means;
    var column1 column2
    output out=final sum=col1sum col2sum;
    run;
    proc print data=final;
    var col1sum col2sum;
    run;
    Hope this helps. Let me know if you have any other questions.
  3. Alex S
    Alex S Second Unit
    Feb 21, 2000
    477
    Dave,
    Thank you very much !!
    [​IMG]
  4. Philip Hamm
    Philip Hamm Lead Actor
    Jan 23, 1999
    6,873
    2
    Proc print? Damn, that's the freekin' Stone Age. proc report roolz. Just ask Ray Pass!! [​IMG]
  5. Dave Morton
    Oct 19, 2000
    753
    Dave
    Alex,
    If you want to use proc report and have trouble, I can help you too. Obviously so can Philip.
    For two numbers, it seems like you only really need the output from the means statement.
    Personally I use either proc report or a data null step to fully control and customize my reports if proc report can't do it.
    Just a matter of preference. Have fun!
