Any 'red-eye' removal tips for scanned in/digital photographs?
Discussion in 'Archived Threads 2001-2004' started by TheoGB, Jul 26, 2002.
  1. TheoGB
    TheoGB Screenwriter
    Jun 18, 2001
    1,744
    I have a lot of photos with red-eye and also even with the 'reduction' on, my digi camera will make people look like they're aliens.
    I've used paintshop packages but it never seems quite 'easy' enough to get rid of.
    I just wondered if there were dedicated packages/methods for getting rid of this stuff in a computer, if you're not a 'graphics' sort of guy!!
    Cheers.[​IMG]
  2. Ben Osborne
    Ben Osborne Second Unit
    Mar 9, 2002
    475
    You mentioned Paint Shop Pro--I would really recommend version 7's red-eye remove tool. All you have to do is drag a circle around the eye and then adjust the color and style until it looks the way you want. I've gotten some good results with it:
    Before
    After
    Edit: Arghhh...stupid Geocities doesn't allow direct-linking. I have to host them on my own PC. The links might not work though since my cable's been on and off sporadically.
  3. DonnyD
    DonnyD Screenwriter
    Jun 12, 1999
    1,145
    Yeah, I have seen this too..... I use a simple and cheap paint shop program (Ulead Express) to take it out with a few simple steps. It is so easy that I haven't looked into any others though.
  4. Rob Gillespie
    Rob Gillespie Producer
    Aug 17, 1998
    3,632
    5
    Paint Shop Pro essentially changes the 'red' eye for another eye. Sounds weird, but it works well if you tinker with the settings and colours.
    PSP is a really good package. It's not Photo Shop, but then it doesn't cost £600 either.
  5. DustinC
    DustinC Stunt Coordinator
    Aug 20, 2000
    59
    All the Adobe Photo Shops that come with printers (like 2.0, 3.0, etc.) remove the red-eye rather well.
  6. TheoGB
    TheoGB Screenwriter
    Jun 18, 2001
    1,744
    Cheers. I'll take a look at PSP. I didn't really get around to checking all its features last time I had it installed.[​IMG]
  7. Jeff Ulmer
    Jeff Ulmer Producer
    Aug 23, 1998
    5,584
    There's always the black eye tool...
